Pocket GPS World :: View topic - GO5100 and Tyre POI's
tonygold
PostPosted: Tue Aug 15, 2017 9:29 am    Post subject: GO5100 and Tyre POI's Reply with quote
hi all
i have always had a little bother when i update my customer base as a POI file and import it to my GO5100 with the Tyre software.
quite often the file will not show on my GO5100 in My Places until i have powered down the 5100 and restarted it (sometimes several times), but eventually it shows up.
i have just updated my list again and although Tyre software reports that the list was synched with my device successfully, it is not there on the GO5100 at all. i have checked that MyDrive is logged in correctly on my 5100 but i now have no list of my customers at all. all of my other (unchanged) POI categories are visible but not the one i need most!!
has anyone else come across this and can advise, as without this POI list i'm in a bit of a bind.
many thanks.
tonygold
PostPosted: Tue Aug 15, 2017 10:00 am    Post subject: Reply with quote
UPDATE
issue solved eventually!!
turns out the usb lead i was using to connect my 5100 to my laptop was a charging cable only and not a data transfer one.
different cable used and POI list has returned.
22.055 (29 May 24)
