tonygold Frequent Visitor
Posted: Fri Jun 24, 2016 7:35 pm Post subject: Via 130 playing up |
Hi guys
I am in Spain and have my tomtom via 130 Western Europe running app 12.071 and it has up to date mapping.
Every couple of minutes it switches from showing the map I'm driving on back to the main menu screen.
The sound instructions continue as normal and if I touch the 'done' button the map navigation screen returns, but only for a minute or two until I press the the 'done' button and so it keeps happening.
I have tried holding down the power button until I get the drum roll but it has not helped.
Any ideas or is it about to go completely kaput on me? It's 3 years old but only used when on hols so very little usage at all.
Many thanks for any advice. |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Fri Jun 24, 2016 11:37 pm Post subject: |
Haven't seen anyone complaining about this sort of behaviour recently, but the advice used to be that dirt trapped between the bezel and the screen might be the cause. Running the corner of a stiffish piece of paper all the way round between the two often cured it.
Worth a try? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Sat Jun 25, 2016 7:30 am Post subject: |
Thanks Anita. Will give this a try. |
Posted: Sun Jul 03, 2016 10:26 am Post subject: |
as i'm back in the UK i can now add an update to this.
Many thanks to Anita. this method seemed to do the trick. although i didnt see any offending dirt particles come out from under the screen, after running a thin business card a couple of times under the bezel, the satnav never played up again, so once again, many thanks for the advice  |
Posted: Sun Jul 03, 2016 12:54 pm Post subject: |
Pleased it worked for you, Tony.
I must admit I had my doubts, especially as you said the verbal instructions continued, but thought, in the absence of any other ideas, it was worth a try. _________________ Anita
UK map 1130.12368
