Posted: Sat Oct 14, 2017 2:51 pm Post subject: Becker MAP PILOT Europa 2017/2018 V15.0 [Q4/2016] Maps
[centre][/centre]
Becker MAP PILOT Europa 2017/2018 V15.0 (Q4/2016) Maps
including Becker MAP PILOT Software + hazardous points-Warner Europe September 2016 + Funny voice: Darth Vader (ger) + Tunnel Sight Pro
So this is the first time I’ve released a set of maps so please bear with me, I’ve tested on an M054 device and works but think it may also work on these models:
M054, M075, M076, M083, M084, M085, M092 & M097 but you will have to test for your self.
It does work slightly different from previous modded versions I’ve downloading in the past so read the instructions carefully.
Instructions:
1. VERY IMPROTANT… back you all the files on the root of your device before you do anything (i.e. drag and drop all the files inside “Becker MP” drive to a safe location on your computer).
2. Once the back up is complete delete all the files from the becker device and empty your trash bin
3. Extract all the .rar files and copy the extracted files onto the becker device without altering any files.
4. Plug into your car and the maps should work.
Now the problem comes if you plug your becker back into the content manager it will not work back in your car until you copy and replace these 2 files on the becker from the download archive:
device.xml and device.xmlt
then you can use in the car again or you can restore the device by restoring all the files you backed up earlier.
Also thanks to testing by valandil314 on his 9077 he got it to work on his 9077 (i assume also M013, M041, M045, M046, M050 und M051, but not sure).
Here is his post with the process he used for earlier becker models:
valandil314;325992]Well, i made this works on 9077 (i assume also M013, M041, M045, M046, M050 and M051, but not sure).
With the old V14 2016-2017 files, i copy APD folder (except navcore.apd file on apd/software), MapRegionsPSF50 and licences folder (/navi/licenses), and the files AutoRun.exe and the 4 device files (device.sig, device.xml, device.xmlt, DeviceInfo.xml).
I also copy the files of CLM folder and copy to the root (because the gps create those files when plug in into the car).
When i plug in the gps into the car, it says maps are valid and it load fine, i also check the map version in the car and it says Q4/2016.
Sorry for my bad english jaja
Update 2...
We now have 2 conformations that valandil314 method works on these 2 older device models 9077 & M013 so an educated guess would be that his method for these older device will work on these models 9077, M013, M041, M045, M046, M050 and M051
Joined: 15/04/2003 12:14:36 Posts: 151 Location: Cheshire, UK
Posted: Tue Apr 24, 2018 6:41 pm Post subject:
Hi Gavla, thanks for the instructions. I just got my unit today which seems to be M054 so it is the one you have tested to work which is quite handy. The maps are 2010 so it would be nice to bring them up to date.
I tried the torrent which didnt seem to be being seeded so I didnt get a download started. I see the link to the file hosting site but it is asking me to accept a plugin that can read all my web activity which seems a little dodgy!
I will see if the torrent bursts into life later.
Thanks again for now.
Ian _________________ TomTom Go 520, HTC Wildfire with CoPilot Live Premium UK & CoPilot Live Standard USA
