Wizzardoz Regular Visitor
Posted: Sat Feb 28, 2015 12:26 pm Post subject: Switch to Micro SD card |
I have a 2699LMT unit with only 60mb left but with a blank 8Gb micro card in it.
Is there a way to switch all files to the SD card so the satnav runs from the SD card? Can the folders be "split" so some of them reside on the SD card rather than the Satnav? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4458 Location: West Sussex
Posted: Sat Feb 28, 2015 12:31 pm Post subject: |
Not easily. What you can try first is delete all unwanted vehicle, voice, text, keyboard, help and EULA files. That should free up a fair bit of space.
A map update is due out next week. Almost certainly you will need the card for that! _________________ Where there's a will ... there's a way. |
Posted: Sat Feb 28, 2015 12:36 pm Post subject: |
sussamb wrote: |
A map update is due out next week. Almost certainly you will need the card for that! |
Ok thanks for this. Can I assume that since I have an empty SD card in the satnav (empty as seen via my PC), Express will automatically use it for more space when maps are updated next week? |
Posted: Sat Feb 28, 2015 12:56 pm Post subject: |
It'll use the card for the complete map if it won't fit internally. It doesn't split the map between the two. _________________ Where there's a will ... there's a way. |
Posted: Sat Feb 28, 2015 1:04 pm Post subject: |
sussamb wrote: | It'll use the card for the complete map if it won't fit internally. It doesn't split the map between the two. |
Thanks. This is what I was hoping for! I will use a 16gb in case I need to add USA to my lifetime Europe ones. |
