Poder Occasional Visitor
Posted: Thu Jul 01, 2004 8:11 pm Post subject: Cannot route to France with SmartST V2 |
I have the Navman 4410 with SmartST V2 and live in Denmark.
I have tried to make a route to France, but it tells me that there was an unknown error making the route, the "route-icon" counts all the way tp 99% before it tells me this.
I can make routes to all of Europe just not France and as I bought the damn thin because of a holiday to France this august, I am a bit disappointed!!!
I have tried to delete the maps of France from my 512 MB SD card and reinstall them with no result.
I have tried to install the service pack 2 with no result.
Does anybody have the same error??
I have also asked Navman about this last week, but the last I asked them a question it took them 1½ month to answer.......
Could it be because there is only 6 MB free on my SD card??
Please help.......august is coming up...... |
DRP Frequent Visitor
Joined: Mar 03, 2004 Posts: 353 Location: "The Green Green Grass of Home"
Posted: Thu Jul 01, 2004 8:24 pm Post subject: |
Hi. Poder
I get the same kind of message, but I thought it was of the English Channel. I have plotted a route to Dover, which is fine. Hopefully when I reach Calais I will be able to plot a route to Le-Mans,(for an over night stop) which is loaded into favorites. Then onto the Dordogne,(which is also in favorites) for the next day. I will be giving an in depth report to this forum as requested be Tim one of the moderators.
I can’t comment on your other points, but watch this space.
Regards
DRP
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Thu Jul 01, 2004 8:27 pm Post subject: |
What are your start and end points and what maps do you have loaded? I only have a 256Mb SD card but will see what I can get on it. _________________ Tim |
Posted: Thu Jul 01, 2004 10:22 pm Post subject: |
Tim Buxton wrote: | What are your start and end points and what maps do you have loaded? I only have a 256Mb SD card but will see what I can get on it. |
My starting point is Denmark (3300) and end point is everwhere in France! As soon as I try just outside of France it is no problem!
The maps I have loaded is:
Denmark
Denmark Outerworld
Schleswig-Holstein
Mecklenburg-Vorpommern
Berlin-Brandenburg
Sachsen-Anhalt
Niedersachsen-Hamburg
Niedersachsen-Hannover
Thüringen
Bayern Nord
Hessen
Niedersachsen-Bremen
Nordrhein-Westf. Duisburg
Nordrhein-Westf. Düsseldorf
Rheinland-Pfalz Nord
Saarland, Rheinland Pf
Luxemburg
Baden-Württemberg
Baden-Württemberg Süd
Bayern Mitte
Bayern West
North East France
South East France
South France
Schwitzerland
North West Italy
Hope this helps!! |
BigH Regular Visitor
Joined: 13/01/2003 19:07:45 Posts: 68 Location: Hampshire
Posted: Sun Jul 04, 2004 5:42 pm Post subject: |
I don't think ST Pro likes going over water, I would suggest you split the plan according to the number of water crossings you are planning.
Regards, |
Posted: Sun Jul 04, 2004 7:34 pm Post subject: |
Poder,
Well, now I've had time, I've loaded enough maps to get from Denmark to France. Unfortunately I only have 256Mb cards and I put the maps onto a CF card fitted into my Navman SE sleeve.
The maps I loaded were
North East France
Denmark
Danmark Outerworld (?)
Schleswig-Holstein
Nordrhein-Westf. Duisberg
Hessen
Nordrhein-Westf. Dusseldorf
Saarland, Rheinland-Pf
Luxembourg
The card had about 6Mb free on it.
I successfully set a route from Munkebo (on Fyn) to Seurre Office du Tourisme and from the Office du Tourisme to the E20 which links Denmark with Sweden (so much for SmartST not routing over water!).
So, I don't know the cure to your problem but I can only say that routing from Denmark to France *is* possible. _________________ Tim |
Steveee Lifetime Member
Joined: Dec 16, 2003 Posts: 203 Location: Colchester, Essex
Posted: Mon Jul 05, 2004 6:19 pm Post subject: |
Is the problem more to do with the number of maps loaded by Poder?
There is a statement somewhere that the more maps used, the more application memory used.
I suggest Poder just selects the maps needed (you can do this in SmartST V2, i.e. the list suggested by Tim. _________________ Steveee
Where am I?
GO 920 (retired)
Garmin Oregon 550T
Garmin Drivesmart |
Posted: Mon Jul 05, 2004 7:49 pm Post subject: |
Steveee wrote: | Is the problem more to do with the number of maps loaded by Poder?
I suggest Poder just selects the maps needed (you can do this in SmartST V2, i.e. the list suggested by Tim. |
Roughly 10% of the total size of the active maps is required to run them, so about 50Mb of programme memory for 500Mb of maps, and that doesn't include the application. _________________ Tim |
Posted: Tue Jul 06, 2004 11:05 pm Post subject: |
Heey...!!
It worked, I reduced the maps loaded and tried again......AND THERE IT WAS!!
It made the route just like that!!
So thanks guys |
