Pocket GPS World :: View topic - Haicom 303MMF and Jornada 568
Goshawk
PostPosted: Mon Jun 28, 2004 9:39 pm    Post subject: Haicom 303MMF and Jornada 568 Reply with quote
Just received a new Haicom 303MMF and want to use it with a HP Jornada 568 using a serial cable. From the CD that came with the 303 MMF it doesn't appear that there are any drivers for the Pocket PC.
The 303MMF has a flashing LED and the GPS Info program that came with it doesn't show any satellite activity. The scan doesn't indicate any particular com port. It just stays on COM 1.
I also tried to find the receiver using CoPilot PC4 and the scan doesn't indicate anything. Hoping someone here has some suggestions on how to get it working.
DavidW
PostPosted: Mon Jul 12, 2004 12:13 pm    Post subject: Reply with quote
The HI-303MMF doesn't need any drivers when used with a Pocket PC - either in CompactFlash or serial mode.
In serial mode, you simply connect the "mini-1394" to "PS-2" cable, then connect your Haicom PDA cable (which must be the one sold for use with a Jornada - assuming such a cable exists; if not, it's down to you to rewire a Haicom cable or make your own) to the "PS-2" connector. You must apply power to the cigarette lighter plug; if you don't, the GPS hardware has no power.
If you have any keyboard drivers installed, disable them - plug in keyboards use the serial port. Your GPS should then be on the serial port (almost certainly COM1:) - NMEA mode, 4800 bps.
22.094 (25 Sep 24)
