Pocket GPS World :: View topic - average speed cams?
average speed cams?
wibbley
PostPosted: Sat Dec 07, 2013 3:04 pm    Post subject: average speed cams? Reply with quote
Just been along the M25 Kent, through the hard shoulder running roadworks & my garmin 3598 with pgpsw speedcams, loaded with csv converter & poi loader does not show the average speed cams.
I'm sure my old tomtom go with pgpsw speed cams, it announced 'average speed camera' with a bright yellow warning icon..
Have downloaded and unzipped the speed cams manually (normally I let csv converter do it) and there is no 'average speed' type file.
interestingly, my voice set up for overspeed for use with csv converter does say 'slow down' past the average speed cams.
Any thoughts?
PostPosted: Sat Dec 07, 2013 3:22 pm    Post subject: Re: average speed cams? Reply with quote
The file will be called 'specs'. Have you got '3rd party POIs' turned on in proximity alert settings?
wibbley
PostPosted: Sat Dec 07, 2013 3:39 pm    Post subject: Reply with quote
Thanks for your swift reply.
Just checked the folder I use with csv converter & there are specs gpx & wav files for all the speeds. Alerts for custom POIs option is ticked.
It maybe that the csv converter voice & pgpsw voice speak at the same time & csv converter is winning for the specs.
Thanks for your help.
PostPosted: Sat Dec 07, 2013 3:52 pm    Post subject: Reply with quote
So you're not using the PGPSW downloads then? Sorry - thought you meant you had used the proper downloads as the GPX conversion wasn't working.
Might be worth trying the actual PGPW files without the conversion. If that works then you know the problem is with the conversion.
Faez
PostPosted: Tue Dec 10, 2013 8:51 pm    Post subject: Reply with quote
I notice on my TomTom Live Xl that the warn when near POI list is missing the pocketgps specs 20 and 30-- Annoying- any no easy way to add them.\/
I have added the latest cameras just now -
Any ideas appreciacted?
Thanks in advance.
Question
