Pocket GPS World :: View topic - mercedes a-class(2013 Model) command online
spacetomcat73
PostPosted: Fri Jul 19, 2013 4:25 pm    Post subject: mercedes a-class(2013 Model) command online Reply with quote
hi
im struggling to get my database to work on my new merc.
ive downloaded the file and done everything it says on the tin and to no avail I just cant get it the file to be seen on the command system
the I have got is by adding a D to the file format to make them GPXD
anyone have a clue what to do?
PostPosted: Fri Jul 19, 2013 5:05 pm    Post subject: Re: mercedes a-class(2013 Model) command online Reply with quote
I'm not sure what you're saying here, did a word get missed out?
Are you saying you have been downloading the .gpx format files, but the Merc sat-nav is expecting ".gpxd"?
I'd never heard of that format so had a look on Google....
One thing I found was this post on GPSBabel, where someone is trying to EXPORT the so-called .gpx files from his merc.
The first answer says this, tellingly....
That's pretty astonishingly broken. They went to all the trouble to make something that looked very much like GPX and then bozoed the implementation so badly that it's not really GPX.
Whatever the issue is (a bit beyond me!) it doesn't look like just adding a "d" to the file extension will be enough!
"Settling in nicely" ;-)
PostPosted: Fri Jul 19, 2013 6:04 pm    Post subject: Reply with quote
We have a specific file set for the Mercedes Comand system. Are you saying that the new version has changed the required format?
22.055 (29 May 24)
