Pocket GPS World :: View topic - Add on's
Add on's
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
hawkhead
PostPosted: Wed Jun 16, 2004 9:05 am    Post subject: Add on's Reply with quote
Finally figured out how to create a shortcut for the postcode finder to use with TT3, there is a lot missing in the OS!
Has ne1 used this?
Morris
PostPosted: Fri Jun 18, 2004 9:01 pm    Post subject: Reply with quote
Hi Hawkhead, yes I use it all the time.
Which postcode software are you using?
Morris
Grzzzzzz Mr. Green
hawkhead
PostPosted: Sat Jun 19, 2004 12:02 am    Post subject: Reply with quote
Morris
http://www.digitools.co.uk/ukpostcode.php
seems to work very well
PostPosted: Sat Jun 19, 2004 6:54 am    Post subject: Re: Add on's Reply with quote
Has ne1 used this?
The easiest way to make a shortcut is to use Explorer on your PC and browse to your handheld via ActiveSync, Tap'n'hold the file you wish to make a shortcu to and select 'Create Shortcut'. You can then cut'n#paste the shortcut to wherever you want it to appear.
As for SPB's Pocket Plus, I prefer OmegaOne's Battery Pack Pro. It has a task switcher, easily configurable access to all your apps and lots of other useful tools Thumbs Up
DavidW
PostPosted: Sun Jun 20, 2004 8:26 pm    Post subject: Reply with quote
I've got both Pocket Plus 2.0 and Battery Pack Pro installed - both have strengths and weaknesses IMHO.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.064 (26 Jun 24)
