Pocket GPS World :: View topic - GPS accuracy query...
major_clanger
PostPosted: Fri Jun 11, 2004 8:46 pm    Post subject: GPS accuracy query... Reply with quote
First off - thanks to Darren et al for all the guidance given to me on this site - thanks to you I now have my GPS and TomTom kit all set up Thumbs Up
One strange query - having been out to test the TomTom (as you do :D ) it has performed brilliantly ... with one exception....
Whenever I'm driving the GPS location seems reasonably accurate. However, when I get home - the TomTom map show me to be about 100 yards away from where I am. Is there any way in which I can "reset" this to show the correct location?
MC
major_clanger
PostPosted: Sat Jun 12, 2004 11:49 am    Post subject: Reply with quote
Update...
I've changed my mind - the GPS is (I think) fine, but the map is wrong!
The road to my house is (it appears) longer on the map than in reality. So, when I turn off to my house the GPS believes I'm turning onto the Green in front of the house. This causes another problem - when I set off in the car, the TomTom software has "GPS location unreliable" because (I suppose) it places me on the Green rather than on a road.
Is this possible, and if so, is there anything I can do about it?
Confused of Shropshire Mr. Green
DavidW
PostPosted: Sun Jun 13, 2004 12:39 am    Post subject: Reply with quote
It's possible there's some inaccuracy in the map. TomTom does 'snap to road' to try to deal with GPS inaccuracy (your GPS position can be some way from your true position), which it does in an intelligent way when routing (as a passenger, watch what happens when the driver takes a different exit from a roundabout to the one suggested - it will often nose down the suggested exit, then realise you didn't got that way after all).
If there's a map error, all you can do is report it to TeleAtlas - I don't have the link on this computer, but hopefully someone will post it. Before reporting a map error, though, get used to how Navigator normally behaves - you may be reporting an error that's more a function of the way the system works.
The "GPS location unreliable" when you drive off is likely because you haven't given the system enough time to get a position fix. This can take a little while.
major_clanger
PostPosted: Sun Jun 13, 2004 8:51 am    Post subject: Reply with quote
David - thanks for the reply - I shall see how it goes over the next couple of weeks
Cheers Thumbs Up
MC
DavidW
PostPosted: Sun Jun 13, 2004 3:35 pm    Post subject: Reply with quote
Just to augment my reply from last night - if you haven't yet got a GPS fix, you should try to stay stationary until you have (it's much harder for a GPS receiver to get a position fix when you're moving).
If you turn out to have a problem with the mapping that you want to report to TeleAtlas, you can do that here.
22.071 (03 Jul 24)
