Pocket GPS World :: View topic - Seidio 2500 background noise
Grahamcol
PostPosted: Fri Jun 04, 2004 5:46 pm    Post subject: Seidio 2500 background noise Reply with quote
Just got my 2500 mount but I am experiencing some slight background noise at 'normal' listening levels using a 3950. Didn't notice this on my Arkon Powered mount with speaker.
I also note that the cover has to remain fitted to the 2500 for it to slip into the cradle.
Graham
vygec
PostPosted: Sat Jun 05, 2004 2:33 pm    Post subject: Reply with quote
i also received my mount this morning, and am getting the same background noise, even at the lowest setting!! Its like a tapping sound, and i get it when there is no other sound being played from the pda.
Any ideas whether my unit is faulty?
minesapint
PostPosted: Sat Jun 05, 2004 2:48 pm    Post subject: Reply with quote
i have got the seidio G2500 mount for the ipaq 2210
its the same with mine, getting the same background noise.
looks like a fault with the seidio G2500 mounts
vygec
PostPosted: Sat Jun 05, 2004 3:07 pm    Post subject: Reply with quote
well i didnt fork out £45 for a unit to work like this!!, surely this cant be the norm with these mounts.. heard only good things before i bought the bloody thing.
Grahamcol
PostPosted: Sat Jun 05, 2004 4:30 pm    Post subject: Reply with quote
Yup. Mine also gets VERY HOT with the 3950 in the cradle. So hot that I now don't use it! Probably give my 3950 heat stroke! Have emailed Seidio about it.
BTW can one connect a bluetooth headset to the 2210 - if so, how?
Graham
andyc
PostPosted: Fri Jun 11, 2004 9:49 am    Post subject: Background Noises Reply with quote
Snap! I thought it was me for a while, has anybody had a response to this? its incredibly irritating
Grahamcol
PostPosted: Fri Jun 11, 2004 3:19 pm    Post subject: Reply with quote
No reply from Seidio after emailing them about the problem.
Just stopped using the thing since it get so VERY hot!!! It is almost to hot to touch! I'm not going to risk my pda in this device!
Graham
tom9851
PostPosted: Sat Jun 12, 2004 7:27 am    Post subject: Reply with quote
Blimey - there was me planning to buy one of these things - after reading this string of complaints I won't be bothering now! Cheers lads indeed!! 8O 8O 8O
___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338
mpb001
PostPosted: Sat Jun 12, 2004 10:56 am    Post subject: Reply with quote
I was also looking at buying one of these.
Is there any more kits like this for the 4150?
Need one that will charge both Ipaq & TT GPS
Mick.
IPAQ 4150 : Kodak 256MB SD.
TTN3 V3.01 : TT BlueTooth GPS.
looking for good all-in-one vent car kit.
tom9851
PostPosted: Sun Jun 13, 2004 12:23 pm    Post subject: Reply with quote
Well Graham mentions Arkon in his post (above). There is also Brodit but I don't think they have their own speaker - which I assume you want just like me due to the poor sound of the Ipaq on it's own.
___________
Grahamcol
PostPosted: Sun Jun 13, 2004 12:38 pm    Post subject: Reply with quote
Still no reply from Seido over my egg-frying 2500.
Anyone know if the Ipaqs' will passively drive a small speaker?
Graham
RobMob
PostPosted: Fri Jun 18, 2004 7:44 pm    Post subject: Reply with quote
Just read this and tested mine and sure enough I get the background noise. Is there a solution. Does it occur in all of these mounts or just particular ones for certain PDA's?
RobMob
Genie
PostPosted: Fri Jun 18, 2004 7:57 pm    Post subject: Reply with quote
I read about this problem a while ago. I think it was on the GPS passion forum and the seidio guys replying on that seemed like amateur electronics guys as one forum member told them how to put it right.
I went for the Arkon powered mount instead and would highly recommend it to anyone thinking about getting a mount.
Works like a charm. I even use it sideways in the rear to play movies on the ipaq to keep the kids quite on a long journey.
Took it to Germany last week and no problems in sweltering heat inside a ford galaxy.
Ipaq 4150, Polstar PBT-111, TomTom3, Kingston 256mb SD, Arkon Powered Amplified PDA Mount
Grahamcol
PostPosted: Sat Jun 19, 2004 12:27 pm    Post subject: Reply with quote
The noise isn't such a big problem as the egg-frying ability of the 2500.
It has been dumped in my ever increasing 'box of useless buys'
Still no reply from Seidio - so what, they've got their money!
Graham
Darryl
PostPosted: Fri Jun 25, 2004 11:54 pm    Post subject: Reply with quote
Graham
Graham - di you buy directly from Seidio? if not you I thought you would be entitled to cover from the retailer Question
I spoke to a retailer about this mount and specifically your problem (because I want to get one) and he said that he had only had "a handful of mounts with the speaker problem - all of which had been returned and replaced" - may be you got one off the production line on Friday afternoon Exclamation if such a thing happens in this high tech world these days
23.054 (28 May 25)
