mevans08 Occasional Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Fri Feb 18, 2011 2:42 pm Post subject: Help Lost POI's on browse screen |
Can anyone help pls ? Just updated PGPSW speed cameras on my GO530 and added some extra POI's from PGPSW. Now when I go to 'details' - 'browse map of route' I can't see any of my POI's on the map....although when I start to use the satnav the POI's appear on the route and function ok !
How do I get the POI's to show up again on 'browse map of route' screen please ? I have them tagged as 'Show POI on Map' ok.
Thanks a lot
Mike |
Posted: Fri Feb 18, 2011 3:04 pm Post subject: |
If you have the POI categories enabled for showing on the map then the only other thing that can prevent them displaying correctly is if you have the screen zoomed out too far - Mike |
Posted: Fri Feb 18, 2011 4:44 pm Post subject: still not there |
Thanks for the quick reply Mike. Nope the POI's won't show up on any zoom level - even in max magnification they just aren't there - but strangely once you start to navigate they pop up on the navigation screen enroute ?
Any other suggestions much appreciated as I am an AA Recovery Driver and I constantly use the 'browse map' feature to pinpoint POI's that I want to head towards. |
Andy_P Pocket GPS Moderator
Posted: Fri Feb 18, 2011 6:05 pm Post subject: |
You didn't say if you've checked that they are enabled to show on the map.
There are a few steps needed to get this working right ....
Go to the 'Browse map' screen
Tap "Options" at the bottom
Now, firstly you should see a screen with "Traffic". "POIs", "Favourites", and "Images"
Is "Traffic" ticked? If it is, that automatically DE-SELECTS all the others. Incredibly annoying! But unfortunately you can't have the map showing Traffic AND POIs both at the same time.
So... un-tick "Traffic" - you must do this before anything else becomes tickable.
Now, is "POIs" ticked? If not, tick it!
At the bottom should now appear another box called "Choose POIs"
Tap it!
Are the ones you want to see ticked?
If they ARE ticked, they should show on the "browse map" screen and all the time on the main navigation screen
If they are not ticked, but you have set up "warn when near" for them in "Manage POIs" then they won't show up on the Browse map, but will pop up on the main navigation screen, this time only when they are within the warning range you set,
That should sort you out.
But... you are quite likely to find that the next time you go to the Browse map screen, the TomTom has "helpfully" switched it back to showing "Traffic" only, so you will have to go back and de-select it all over again to get the POIs showing once more. (Drives me mad!) |
Posted: Fri Feb 18, 2011 6:28 pm Post subject: PGPSW Rules ! |
Andy you're the man ! Thanks very much - problem solved in 2 minutes !
My PGPSW membership is worth every penny and not just for the speed cameras - you have a lifelong member !
Yours gratefully
Mike |
Posted: Fri Feb 18, 2011 9:06 pm Post subject: |
![Cheers!](modules/Forums/images/smiles/custom14.gif) |
