Pocket GPS World :: View topic - tom tom poi distance alerts lost
gus11
PostPosted: Wed Dec 15, 2010 9:26 pm    Post subject: tom tom poi distance alerts lost Reply with quote
Confused just loaded a map update from tom tom and have now lost all my distance alerts for poi. its a pain in the bum to reset all cameras and others. are my poi in the wrong file location. at the moment they are in the western europe map location.
ta, Gus
PostPosted: Wed Dec 15, 2010 10:24 pm    Post subject: Reply with quote
No, you've done it right, the map folder is the correct location.
When TomTom Home upgrades your map, it ALWAYS used to lose the file that has all your settings (MapSettings.cfg).
TT have made great efforts to fix that, and a lot of people now find it DOES copy the file across correctly.
However I'm afraid it still fails for a significant number of people for some unknown reason.
If you have made a backup of your system before you did the update (if not, you REALLY should have done...) then you should be able to find that file in your backup's map folder and copy it into the new one, replacing the new file of the same name.
Sometimes this doesn't work at first, causing the device to re-boot when you switch it on. The "fix" for that is to run the on-screen emulator in "Home" and add a new favourite. That re-writes the file and makes it usable.
(PS I'll move this to the TomTom forum section)
