Pocket GPS World :: View topic - kenwood dnx7240bt
kenwood dnx7240bt
kimsmith
PostPosted: Thu Sep 09, 2010 7:45 pm    Post subject: kenwood dnx7240bt Reply with quote
I have installed the speed camera software and it works ok, but the sound for the alerts is very soft, can this be turn up????
PostPosted: Thu Sep 09, 2010 8:56 pm    Post subject: Reply with quote
Depends on several factors. Are yo using one of the voice packs from here for the alerts or a built in sound on the Kenwood?
I don't know the Kenwood at all, I guess you've checked all the menus for different volume controls?
If it's one of the voices from here, I would normally say that they have all been recorded to maximum digital volume, but I recently discovered that they have used an older version of one of them (possibly Kate) and the latest "Nick" is very quiet. Try another voice? (and please report back if it's an improvement so I know which one to fix!)
kimsmith
PostPosted: Fri Sep 10, 2010 7:33 pm    Post subject: Reply with quote
thanks for your reply Andy
Its not a voice but the alerts sound or tone i mean. Say as your driving and the sat nav flashes up on the screen speed cam the sound for the alert is very quite, i did download the POI camera's from this site
thanks kim
PostPosted: Fri Sep 10, 2010 7:38 pm    Post subject: Reply with quote
If the Kenwood is based on a Garmin in the background, You may be able to use our voice alerts instead.
Sorry to be vague, but I don't know the Kenwood models at all.
cjay2412
PostPosted: Sat Sep 11, 2010 1:09 pm    Post subject: Reply with quote
you can use voice alerts on the kenwood but it is not a straight foward process. the files muct be in mono wav format. if anyones interested i could post a guide on how i got voice alerts on my unit
PostPosted: Sat Sep 11, 2010 1:14 pm    Post subject: Reply with quote
That would be very useful.... Smile
cjay2412
PostPosted: Sat Sep 11, 2010 7:43 pm    Post subject: Reply with quote
software needed
http://audacity.softwaredl.net/ audacity
http://www8.garmin.com/support/download_details.jsp?id=927 poiloader
http://sourceforge.net/projects/sox/files/sox-win/14.3.1/ sox.exe
(Note by Andy_P - the new download system for the voice warnings allows you to download DIRECTLY in .wav format, so there's no need to go through any of the steps with Audacity (unless you want to change the volume of the individual files)
Before you start download sox.exe and save it to the same folder as poiloader (usually called gamin)
1 download and extract your camera warning files remembering where you extracted them to
2 open audacity then click file then open the audio file you need to convert
3 if your file is stereo then we need to convert it into a mono format to do this click on the down arrow in the left hand gray box near the top select split stereo track then click on the same down arrow again and select mono then delete the bottom track
4 then click file then export as wav file and save in the same folder as your extracted speed cameras note the audio files must be called the same as speed cameras i.e
gatso20.wav
gatso20.csv
5 once you have repeated this process with all the audio files you then run poiloader as you normally would if all goes well then the resultant poi.gpi file should be around 7mb give or take
if you find your warnings too quite/ loud then use audacity to increae/decrease the volume using the + - slider fond to the left hand side of the track
hope this helps
PostPosted: Sun Sep 12, 2010 12:41 am    Post subject: Reply with quote
Thanks! I hope other Kenwood users find this helpful. Smile
kimsmith
PostPosted: Tue Sep 14, 2010 6:51 pm    Post subject: Reply with quote
thanks as soon as i have had a go i will let you know
kimsmith
PostPosted: Fri Sep 17, 2010 9:19 pm    Post subject: Reply with quote
ok cjay
i have given this a go but in my poi folder there are no files that audacity will open its saids incorrect format. the files list are bmp or csv files i have tested all files????
kim
cjay2412
PostPosted: Sat Sep 18, 2010 1:55 am    Post subject: Reply with quote
you need to download one of the voice alerts from here http://www.pocketgpsworld.com/speed-camera-alerts-garmin.php
convert these files then add them to your speed cam folder
22.094 (25 Sep 24)
