Pocket GPS World :: View topic - Speed camera database
philby87
PostPosted: Tue Aug 31, 2010 4:33 pm    Post subject: Speed camera database Reply with quote
I have used a Tom Tom for some years now and regularly update the speed camera database from this site and found it easy to install the updates.
I am now thinking of buying a Garmin nuvi. Can anyone tell me if it is as easy to update the Garmin a sit was the Tom Tom?
redsquirrel
PostPosted: Tue Aug 31, 2010 4:42 pm    Post subject: Reply with quote
It's very easy - just point the POILoader software at the files. I have never owned a Tom Tom so cannot compare them though.
Red Squirrel
Garmin Nuvi 660FM
DriveSmart (pending disposal Sad )
Wazza_G
PostPosted: Tue Aug 31, 2010 5:09 pm    Post subject: Reply with quote
It depends which Garmin you go for! The 37xx series it can be a nightmare to get them in.
It's OK once you've sussed out how to do it though. Hopefully the next firmware update will make the 37xx series's glitches disappear and make it easier to install the camera database.
PostPosted: Tue Aug 31, 2010 6:10 pm    Post subject: Reply with quote
can you tell us how the process differs from the other garmins so we can update the installation guide?
Wazza_G
PostPosted: Tue Aug 31, 2010 6:28 pm    Post subject: Reply with quote
The best way seems to be to copy the existing POI folder on the Garmin 37xx series on to your computer as a backup, then delete the POI folder & replace it with a folder called POI, that way you can say for sure that the folder is completely empty.
Then use POILoader to install the cameras to the POI folder & it seems to work when you activate the Custom POIs.
The other method is to save them to a memory card via POILoader (it usually creates a folder garmin/poi), which seems to have the same result.
You can only use the 24x24 Icons with the databases, if you use the 44x44 ones then they just appear as a small blue dot.
23.084 (27 Aug 25)
