Pocket GPS World :: View topic - Nuvi 200
Nuvi 200
kompressorgpl
PostPosted: Thu May 06, 2010 6:42 pm    Post subject: Nuvi 200 Reply with quote
Hello! My Nuvi 200 3D is very slow. Ie: I'm on the road and there is a cross on my right. In the GPS will only appear long after you have gone through it. Another thing: it is possible to install a software Igo on the NUVI? Thanks!
smithdwsn
Spammer
PostPosted: Wed May 12, 2010 1:30 pm    Post subject: Reply with quote
I have purchased a new Nuvi 200 just before a month but i have not faced any problem yet. It has great features and fucntionalities. It includes high sensitivity wass enabled receiver, display, Unit dimensions, Weight, Battery: up to 5 hours of battery life depending on use. It also include an anti-theft feature.fingertip touchscreen interface,built in travel kit, sb card slot.
[url=http://www.r4-kaart.nl/]acekard ds[/url]
PostPosted: Wed May 12, 2010 1:49 pm    Post subject: Reply with quote
hi
garmin use a propitiatory operating system and you can't install any other software on it.
what car do you have and does it have an athermic windscreen? that may be affecting the satellite fix. do you have any other GPS devices you could use to see if the windscreen is affecting the signal? you could also try having a passenger hold the satnav out the window* to see if that makes it any better? if it does then you can probably blame the windscreen!
* THIS IS AT YOUR OWN RISK!!!!
22.062 (12 Jun 24)
