Pocket GPS World :: View topic - GARMIN ZUMO 550 - Jeffs fed up (installing camera files)
Jeffrs
PostPosted: Sat Apr 03, 2010 10:51 am    Post subject: GARMIN ZUMO 550 - Jeffs fed up (installing camera files) Reply with quote
Sad Hi sorry to be a pain, i have just subscribed and i am lost. I have managed to down load to vista based pc. I am showing file to 7 zip, after this nothing will happen, keeps asking me to select file showing indervidual files, but nothing will work. Is there any advice step by step for a numpty to use? Thanks in hope of a happy time. Jeff
BigPerk
PostPosted: Sat Apr 03, 2010 11:19 am    Post subject: Reply with quote
Can't give any specific help I'm afraid, but the last post in the thread
Vista issue - problem when unzipping speedcam download
suggests possible unzip problems with Vista. There may be other clues on here if you do a search (use 'all terms' with you search keywords, and list results by 'post').
Hopefully Darren et al, will be able to guide you better!
(Navigon 70 Live, Nuvi 360)
PostPosted: Sun Apr 04, 2010 12:45 pm    Post subject: Reply with quote
Hi, sorry you've not had much in the way of replies, I guess Easter means less people are on-line than usual.
However,as a total aside, I've just (finally) got a mobile broadband dongle working for the first time ever, so I came to this page as a test and you're getting this reply from a field in Kent!
So, just a couple of things to get started...
I'm not sure what you mean when you say "I am showing file to 7 zip... ",
I would think you should be downloading a file called something like "pgpsw-speed-cams-xyzAB.zip"
Using Windows Explorer, find wherever your PC has saved it and right click on it. A menu should appear and one of the options should be "extract all". Follow the prompts to "unzip the folder full of camera files.
Once that is done, you should be able to follow the instructions
HERE or there is a video guide HERE.
Try one of those and if you still have problems, write back and say where (which step) it all goes wrong for you.
22.063 (19 Jun 24)
