Pocket GPS World :: View topic - Nuvi 360 can't unlock maps - Help
raymonds
PostPosted: Mon Apr 07, 2008 6:37 am    Post subject: Nuvi 360 can't unlock maps - Help Reply with quote
Hi, i have NUVI 360 which i load a new maps from pc to nuvi base folder.
upon reboot nuvi, it prompted "Can't Unlock Maps"
no matter what i do, the massage remains and new map not loading, only the preloaded map is available.
i have tried to reset the unit with reset button and holding upper right and power up... the massage still there...
pls help me, what must i do?
thanks. Crying or Very sad
PaulB2005
PostPosted: Mon Apr 07, 2008 8:00 am    Post subject: Reply with quote
HI and welcome.
What maps are you loading?
Do you have an Unlock Code for the map?
raymonds
PostPosted: Mon Apr 07, 2008 9:42 am    Post subject: Reply with quote
thanks.
i loaded a Taiwan maps from a disc. it has been unlock on my pc with 25 char keys.
i cant do anything about it right now... whenever i boot my nuvi360, the same old massage will prompt...
what could have go wrong?
i have tried upload map to a SD card and plug into nuvi360 but it don't make a different.
thanks
PaulB2005
PostPosted: Mon Apr 07, 2008 9:56 am    Post subject: Reply with quote
Please keep all questions and communication in the forum. This helps everybody see whats going on and centralisies the information.
raymonds
PostPosted: Tue Apr 08, 2008 5:17 am    Post subject: Reply with quote
thanks,
is there away i can disable the message?
pls suggest what other thing i can try out?
thanks.
PaulB2005
PostPosted: Tue Apr 08, 2008 8:12 am    Post subject: Reply with quote
Where did you buy the maps from and what maps were loaded before?
Where did you load the maps to? Internal Memory or SD Card?
What maps EXACTLY did you installed? What does it say on the DVD?
From Garmins website.
If you are getting a message on your unit stating; Can't unlock maps; then proceed as follows:
Open the Notepad program on your computer by clicking the Start menu, All Programs, Accessories, Notepad.
Type in the Unlock Code for the current version of the map software WITHOUT dashes or spaces.
Click the File menu and click Save As...
At the bottom where it says Save As Type: click the down arrow next to this box and click All Files.
Click to check the box next to file name and type in gmapprom.unl
Click the down arrow next to Save in: and click on Desktop.
Click Save to save the file to your Desktop.
Close the Notepad and right-click on the file that you just saved then click Copy.
Connect the nüvi® to the computer's direct USB 2.0 port (no hubs) and double-click My Computer
Double-click the Garmin/nüvi drive
Double-click the Garmin folder.
Click the Edit menu and click Paste. If it asks: if you want to replace the file, click Yes to replace it.
Disconnect your unit from the computer and let it restart.
Proceed at your own risk
Also
If you are getting a Can't Unlock Maps message, you have a problem with the unlock code on your unit. If your GPS is not a preloaded device, you may need to verify that you are using the correct unlock code and re-install your mapping software.
If your GPS is a preloaded device, such as a nüvi, or if you cannot get this issue fixed with this information, please contact Garmin for further troubleshooting.
Repsol1000
PostPosted: Thu Mar 04, 2010 10:32 am    Post subject: Reply with quote
You need to delete one file (gmapsupp.img) You will find it in the Garmin folder of your Sat Nav it holds the wrong keycode for the map you have loaded
22.064 (26 Jun 24)
