Carll Occasional Visitor
Joined: Feb 29, 2004 Posts: 44 Location: Dartford, Kent, UK
Posted: Sat May 22, 2004 9:32 am Post subject: Dell Axim X5 and BT |
Having done alot of research on the Internet, I have got my X5 to work with the BT CF card that Dell said was broken!
http://forums.us.dell.com/supportforums/board/message?board.id=aximwireless&message.id=2109&view=by_date_ascending&page=2
This link explains how to get all BT cards working on the X5, and the shear fact that Dell are chosing not to fix this well documented problem.
The fix even for a thicko like me was easy, but did need a hard reset, so make sure you have backed up the data first!
You need the com1 drivers (third party) and a registry editor
http://www.com1-support.com/archive/TECH0850_Pocket_2000_2002.zip
http://www2r.biglobe.ne.jp/~tascal/...c/regedit_e.htm
1. Install the tascal registry editor
2. install the com1 drivers
3. Select all the text between but not including; start copy to end copy below, then copy and paste it into notepad on you PC. Go file, save as bluetooth.reg. You need to copy it to your AXIM using explorer. You'll see your Axim in MyComputer as a folder called MobileDevice. It does have to be cradled for this....
4. Import the .reg file using the tascal registry editor - this should change all the relevant settings. To do this run Tascal regedit, go File, Import registry. It defaults to search all folders so it will find the .reg file if it's there.
5. Soft Reset the AXIM - everything should work. BTW - you do this by pressing the stylus into the reset pin located below the twiddley swith on the right side of the AXIM.
Start copy
REGEDIT4
[HKEY_CURRENT_USER\Comm]
[HKEY_CURRENT_USER\Comm\RasBook]
[HKEY_CURRENT_USER\Comm\RasBook\`BlueToothActiveSync]
"Entry"=hex:\
18,03,00,00,01,00,00,00,01,00,00,00,00,00,39,00,39,00,39,00,39,00,39,00,39,\
00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,39,00,\
39,00,39,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,00,64,00,69,00,72,\
00,65,00,63,00,74,00,00,00,6D,00,20,00,57,00,69,00,64,00,63,00,6F,00,6D,00,\
6D,00,20,00,57,00,69,00,64,00,63,00,6F,00,6D,00,6D,00,20,00,42,00,54,00,20,\
00,4E,00,75,00,6C,00,6C,00,20,00,4D,00,6F,00,64,00,65,00,6D,00,00,00,00,24,\
F4,F5,08,80,00,00,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,00,00,02,1A,00,\
00,00,00,00,00,00,1A,F4,F5,08,80,00,00,02,1C,00,00,00,00,00,00,00,1C,F4,F5,\
08,80,00,00,02,1A,00,00,00,00,00,00,00,1A,F4,F5,08,80,00,00,02,1C,00,00,00,\
00,00,00,00,1C,F4,F5,08,80,00,00,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,\
00,00,02,1C,00,00,00,00,00,00,00,1C,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,\
00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,\
2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,\
2D,00,2D,00,2D,00,2D,00,2D,00,2D,00,00,00,2D,00,2D,00,2D,00,2D,00,2D,00,2D,\
00,2D,00,2D,00,2D,00,2D,00,00,00,00,00,00,1A,F4,F5,08,80,E8,EB,02,1C,00,00,\
00,00,00,00,00,1C,F4,F5,08,80,E8,EB,02,22,00,00,00,00,00,00,00,22,F4,F5,08,\
80,E8,EB,02,20,00,00,00,00,00,00,00,20,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,\
00,00,00,1C,F4,F5,08,80,E8,EB,02,24,00,00,00,00,00,00,00,24,F4,F5,08,80,E8,\
EB,02,24,00,00,00,00,00,00,00,24,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,\
00,1C,F4,F5,08,80,E8,EB,02,1A,00,00,00,00,00,00,00,1A,F4,F5,08,80,E8,EB,02,\
1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,\
F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,E8,EB,02,1E,00,\
00,00,00,00,00,00,1E,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,F5,\
08,80,E8,EB,02,24,00,00,00,00,00,00,00,24,F4,F5,08,80,E8,EB,02,1C,00,00,00,\
00,00,00,00,1C,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,\
E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,\
00,00,1C,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,F5,08,80,E8,EB,\
02,1A,00,00,00,00,00,00,00,1A,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,\
1C,F4,F5,08,80,E8,EB,02,1A,00,00,00,00,00,00,00,1A,F4,F5,08,80,E8,EB,02,1C,\
00,00,00,00,00,00,00,1C,F4,F5,08,80,E8,EB,02,1C,00,00,00,00,00,00,00,1C,F4,\
F5,08,80,8C,D3,05,26,00,00,00,00,00,00,00,26,F4,F5,08,80,8C,D3,05,24,00,00,\
00,00,00,00,00,24,F4,F5,08,80,8C,D3,05,18,00,00,00,00,00,00,00,18,F4,F5,08,\
80,0F,00,00,00,00,00,00,00,C4,B3,00,F0,00,00,00,00,90,6E,06,00,80,6E,06,00,\
01,08,00,00,00,00,00,00,10,01,00,00,F4,3D,C5,01,D4,EB,06,80,F1,EC,FF,FF,00,\
00,00,00,1F,00,00,00,CC,0C,00,00
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial1]
"Index"=dword:00000008
"FriendlyName"="Bluetooth Serial Port COM8:"
"DeviceArrayIndex"=dword:00000008
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Serial2]
"Index"=dword:00000005
"FriendlyName"="Bluetooth Serial Port COM5:"
"DeviceArrayIndex"=dword:00000005
[HKEY_LOCAL_MACHINE\SOFTWARE\Widcomm\BtConfig\Applications\0001]
"ComPortNumber"=dword:00000008
[HKEY_LOCAL_MACHINE\SOFTWARE\Widcomm\BtConfig\Services\0001]
"ComPortNumber"=dword:00000005
[HKEY_LOCAL_MACHINE\SOFTWARE\Widcomm\BtConfig\SerialTransport]
"BaudRate"=dword:00F42400
End copy _________________ iPAQ 5550; 400MHZ - 256 SD Card - TT wired GPS - TTN3 UK - PPC 2003 |
