Pocket GPS World :: View topic - Uploading UK and European Speed cameras to Garmin KNA G520
appletonc
PostPosted: Sat Dec 05, 2009 12:33 pm    Post subject: Uploading UK and European Speed cameras to Garmin KNA G520 Reply with quote
Is it possible to put both UK and EU speed cameras onto my Garmin device? When I tried, the UK cameras stopped showing.
PostPosted: Sat Dec 05, 2009 4:19 pm    Post subject: Reply with quote
Yes you can, but there's a trick to achieving it.
The problem (as with any POIs) is that you need to load them ALL AT ONCE with POI Loader, if you use it again, it wipes out the first lot.
The way round it for POIs in general, is to keep a folder on your PC where you store all your POIs, and when you want to add some more to the Garmin, you add them to that folder first and then upload the whole lot every time.
The same will work for the camera data, except a problem arises over the filename speed definitions - POIloader asks at the initial stage whether you want to use MPH or KPH and for UK files @50 means 50mph, but for European files @50 means 50kph.
Anyway, enough background info/rambling....The way round it is described in full HERE Smile
22.071 (03 Jul 24)
