daveapace Occasional Visitor
Posted: Thu Nov 12, 2009 6:42 pm Post subject: Loading poi's to SD Card |
Hi all,
First, great site. Now for my problem.
I have just loaded speed cams poi to my Kenwood KNA G421V system and it has loaded ok. Now if I want to load a poi for LPG as well I need to do it at the same time as the speed cams poi, but when I use POIloader to put them on my SD Card it calls them both 'poi.gpi'. So how do I load both at the same time?
Hope you can help.
Many thanks. Dave. |
BigPerk Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_016.gif)
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Thu Nov 12, 2009 7:03 pm Post subject: |
I think you need to put ALL your POIs into ONE folder, then 'POILoader' that. _________________ David
(Navigon 70 Live, Nuvi 360) |
Rebel154 Occasional Visitor
Posted: Thu Nov 12, 2009 9:56 pm Post subject: |
BigPerk wrote: | I think you need to put ALL your POIs into ONE folder, then 'POILoader' that. |
BigPerk is correct. You need to put all your POIs and camera files (which are treated as POIs) into the same folder and then point POI Loader at that folder. It will create a single poi.gpi file containing all your POI/camera data.
Note that if you wish to update the cameras (or add other POIs) you need to ensure that data for all your POIs are in the folder as the file overwrites existing data when loaded into the Nav unit. It's an all or nothing system when it comes to POI updates. |
Posted: Thu Nov 12, 2009 11:15 pm Post subject: |
Many thanks for the prompt replies. I have done what you suggest and it works. I subcribed to pocket gps world today and the responce to my question is amazing quick.
Again many thanks for your help.
Dave. |
DaleyP Occasional Visitor
Posted: Fri Feb 19, 2010 9:43 pm Post subject: |
Going one step further with this thread, does anyone have any idea how to combine both UK and European camera files when using POILoader?
The download instructions (which worked brilliantly well, especially compared to those given by Kenwood for their updates...) put a high importance on the units of measure, i.e feet and MPH if in the UK and metres and KPH if in Europe. So what settings should i use to download a combination so it still works when i cross the channel?
Am i over complicating it and it is just a matter of changing the units on my DNX7240BT or is it not possible?
I'd be really grateful for any input. Thanks |
![](modules/Forums/images/avatars/gallery/Sphere_animated2.gif)
Posted: Sat Feb 20, 2010 11:16 am Post subject: |
This works for Garmin units so I'd imagine it'll work for the Kenwood units.
Basically load the UK (MPH) files to the card then rename the file to POIUK.gpi, then run POILoader again for the EUR (KPH) files making sure you change the units in POILoader to KPH and load both files to the unit.
You could do the same to separate your speed cameras and normal POIs too. However I'm not sure this has been tested with the Kenwood units.
Not sure if you need to change the Kenwoods units to KPH when you cross the channel though... |
