STONEYBROKE Occasional Visitor
Posted: Fri May 14, 2004 11:03 pm Post subject: hooking up tomtom with cassiopeia |
tomtom gps cable for e-115 cassiopeia pda.
sold as tomtom spare a couple of years ago...but now vanished from this earth.
does anyone know a supplier which might actually have one.
failing this,i quite fancy risking everything by making my own.
could i use the docking cradle which has the serial connector attached.
any info on pin outs much appreciated .
thanks in advance |
lbendlin Pocket GPS Staff
Posted: Fri May 14, 2004 11:19 pm Post subject: |
Yes, you could abuse the docking cradle. You only need four pins
- Vcc (mostly red)
- Gnd (mostly black)
- TxD (green or yellow)
- RxD (white or brown)
If it doesn't play, try swapping RxD and TxD. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun May 16, 2004 8:06 pm Post subject: |
thanks for the info...but,
the 9 pin d serial connector has wh/grn/br/ylw + others connected.
deciding which 2 of these will be suitable as rcv/tx to gps rcv is a problem.
also the tomtom rcv-does it need 12v or a lesser voltage?
quick re-cap (more for my benefit than anyone else's)
using docking cradle connected to the pda-this cable terminates in serial d conn
i make jumper lead with 9 pin male d conn to rj45 skt to fit tomtom gps rcv.
(connecting external dc source for gps rcv if not available at serial conn.)
ttnav 3 works perfect and i never get lost again!!
what do u think? |
Posted: Sun May 16, 2004 9:17 pm Post subject: |
The receiver needs 5V, so you can get that directly from the serial connector (Vcc). You could use your approach - I have done something similiar with my iPAQ here : http://pocketgpsworld.com/lutzincar.php _________________ Lutz
Posted: Sat May 22, 2004 10:25 pm Post subject: |
ROUTEPLANNERS.CO.UK --THEY KNEW THE LEAD HAD NOT CHANGED FROM TTNAV 2 AND HAD ONE IN STOCK.NEXT DAY DELIVERY .
EXCELLENT
SOLDERING IRON AND WIRE CUTTERS PUT SAFELY AWAY. |
