grajay Occasional Visitor
Joined: Jul 30, 2009 Posts: 3 Location: Bucknell, SHropshire
Posted: Fri Jul 31, 2009 11:06 am Post subject: Garmin unit to USB cable |
Does anyone know if these cables are common to all units please?
I have a Garmin 60csx handheld, and have just bought s Garmin nuvi 1490T. The cables look similar but not identical although the connectors at either end fit both units.
Thanks |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Jul 31, 2009 2:04 pm Post subject: |
They should be the same. There is a standard for usb leads, most manufacturers follow it. BUT, some don't
I leave plugged in and use one of my Garmin leads for all my devices that I plug in to my PC. Different makes of gps unit, video camera, archos 380 media player etc., and all work okay. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Fri Jul 31, 2009 3:42 pm Post subject: |
the garmin streetpilot i3's usb lead wasn't a standard usb lead... it would ONLY work with the supplied lead, whereas the nuvi series work with any usb lead.
maybe the i3 was a one-off or it could be that the older devices used non-standard usb devices and they 'fixed' it with newer devices?
best thing is to give it a try! the worst case scenario is that it won't transfer stuff
MaFt |
Posted: Sat Aug 01, 2009 4:59 am Post subject: |
Thanks guys - I'll give it a go. |
Posted: Sat Aug 01, 2009 2:49 pm Post subject: |
MaFt wrote: | the garmin streetpilot i3's usb lead wasn't a standard usb lead... it would ONLY work with the supplied lead, whereas the nuvi series work with any usb lead.
MaFt |
That's very strange. I have only ever owned Garmin i3's from their range. And its definitely one of those leads I use all the time. Garmin label on it and one of those magnetic bits as well.
After 10 min search found another i3 box. Tried the lead out of there and it works with everything I have just plugged in, including my TT ONEv4 and a RoadPilot MicroGo.
Also just plugged in the TT ONE lead and both the i3's I have at hand work okay with it. Tried PoiLoader and it works on both i3's |
Posted: Sun Aug 02, 2009 6:30 am Post subject: |
Just to dot the i' & cross the t's- I can confirm that the nuvi cable works fine with my 60Csx. Thanks again. |
Posted: Sun Aug 02, 2009 11:47 am Post subject: |
grajay wrote: | Just to dot the i' & cross the t's- I can confirm that the nuvi cable works fine with my 60Csx. Thanks again. |
Thank you grajay for letting us know |
