Barney Occasional Visitor
Joined: Jan 14, 2004 Posts: 20 Location: Stockport, Croydon UK
Posted: Mon May 10, 2004 2:10 pm Post subject: Satellite fix problem Tom Tom setup |
Hardware: Tom Tom 2.00 (323), Tom Tom mouse (not bluetooth) Ipaq 3970.
While driving down from Scotland yesterday after working normally for about 30 mins, my setup lost satellite fix.
Examining the GPS data, the unit could see at least 6 satellites at all times, the satellite clock was running (1st June 2003 and 1 hour slow, but running all the same).
Despite being able to see up to 9 satellites all remained grey and the mouse refused to lock on (light blinking red) for the remainder (about 2.5 hours) of the journey. I was therefore not getting GPS data through to Tom Tom.
While tinkering with the IPAQ, I reset the GPS source to NMEA 0183v2 4800 this showed the same greyed out signal feed, resetting back to Tom Tom on com 1 had no effect.
I tried several soft resets, and self tested the Ipaq to no avail.
Any ideas?????????? |
lbendlin Pocket GPS Staff
Posted: Mon May 10, 2004 3:53 pm Post subject: |
try it again, with the receiver in plain sky sight (outside of the car). Set your GPS to COM1, NMEA 4800 (as you did once)
(You seem to have a pretty old version of TomTom. You should at least have 2.24 and the GPS version 2.07) _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Joined: 30/12/2002 17:36:20 Posts: 4918 Location: Oxfordshire, England, UK
Posted: Mon May 10, 2004 4:03 pm Post subject: |
Barney,
Have you tried TTNav 2.24?
That was/is a very stable version and can be download from here
Which GPS Driver are you using? 2.07 is also pretty stable and can be found in the PocketGPS World download page.
Garmin Camper 770 LMT-D |
Posted: Mon May 10, 2004 5:26 pm Post subject: |
Thanks for the swift replies!!!! :D
I'll make sure I'm up to date with drivers etc, (was thinking of upgragding to TT3 but that's a WHOLE other story!!!).
I'll let you know the outcome.
Cheers!! |
Posted: Mon May 17, 2004 10:58 am Post subject: |
:D
System working after installation of new GPS driver and Tom Tom update as suggested.
Thanks!!!!!!!!!
One further question/comment, I now seem to be locking onto fewer satellites than before, and the satellite lock is lost very easily (like goung under bridges etc) has anyone else experirnced this??
I'm beginning to suspect a hardware (GPS receiver) fault.. |
alix776 Pocket GPS Moderator
Posted: Tue May 18, 2004 5:38 pm Post subject: |
2.09 is a stable version or you could go to 3.01 that should work to _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Tue May 18, 2004 6:41 pm Post subject: |
Thanks for the tip Alix (Nice Avatar!!!)
I looked on the download page (on this site), and on TOM TOM site, can't find any links to later drivers than 2.07???
Barney |
DavidW Pocket GPS Moderator
Posted: Wed May 19, 2004 10:30 am Post subject: |
GPS 3.02 is available somewhere on the TomTom Support site - direct links are all but impossible to those pages.
GPS 2.07 is the version you'll find in the download area of this site. it's the last version of TomTom GPS that doesn't include the intrusive driver that can block other Bluetooth applications from using your Bluetooth GPS.
2.09, in particular, is not recommended - it's a stable enough version of TomTom GPS, but it includes not only the interfering driver (as all the 3.xx versions of TomTom GPS do), but it includes the first, rather troubled version of TomTom Wizard.
David |
joejoe123 Occasional Visitor
Joined: Mar 06, 2004 Posts: 39 Location: Vienna , Austria
