FXRStuarty Regular Visitor
Posted: Thu Jul 23, 2009 7:23 pm Post subject: MS AutoRoute and Garmin |
Can I download routes from MS Autoroute to my 760T?
TIA  |
gatorguy6996 Frequent Visitor
Joined: Feb 16, 2008 Posts: 695 Location: Florida, USA
Posted: Thu Jul 23, 2009 8:47 pm Post subject: |
Yes, but IIRC you will need a conversion program like GPSBabel to put it in the proper format. _________________ Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Jul 23, 2009 9:22 pm Post subject: |
POIConverter, from out own Oldie can read the AuitoRoute .AXE files, and export them in several formats. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Thu Jul 23, 2009 11:31 pm Post subject: |
Then that's even better!  _________________ Garmin 1695 / 255 / 760 w/MSN - Droid w/Google nav + Navigon - Navigon 8100T - Dakota10 - GPSMap76C - GeoMate Jr. |
Posted: Sun Jul 26, 2009 10:12 am Post subject: |
Oldboy wrote: | POIConverter, from out own Oldie can read the AuitoRoute .AXE files, and export them in several formats. |
This looks like what I need so I have downloaded it to my laptop.
Have had a wee look at it and tried to load a saved journey constructed using Autoroute.
When I try to load the route in to POI Converter the file does not show in windows explorer. I assume this is due to the file extension. POI C looks for .csv files and my saved file is a .axe and the only other option is .axt
Where am I going wrong?
Grateful for further guidance.
TIA  |
Posted: Sun Jul 26, 2009 11:05 am Post subject: |
FXRStuarty wrote: | When I try to load the route in to POI Converter the file does not show in windows explorer. I assume this is due to the file extension. POI C looks for .csv files and my saved file is a .axe and the only other option is .axt | Select as Filetype Microsoft Maps.  _________________ Richard
Posted: Sun Jul 26, 2009 11:35 am Post subject: |
Oldboy wrote: | FXRStuarty wrote: | When I try to load the route in to POI Converter the file does not show in windows explorer. I assume this is due to the file extension. POI C looks for .csv files and my saved file is a .axe and the only other option is .axt | Select as Filetype Microsoft Maps.  |
Thanks.
I did as you said and, after inserting the push pins, I now have a list of 11 journey points shown as Push Pins.
I have a Garmin 760 and so I saved this as a Garmin file. Is this correct? After connecting my Garmin to my laptop how do I get this in to my Garmin? Where should the journey be saved? On the SD card?
Sorry for the dumb questions but this is all new to me.  |
Posted: Sun Jul 26, 2009 5:09 pm Post subject: |
FXRStuarty wrote: | I have a Garmin 760 and so I saved this as a Garmin file. Is this correct? After connecting my Garmin to my laptop how do I get this in to my Garmin? Where should the journey be saved? On the SD card?
Sorry for the dumb questions but this is all new to me.  | I'm afraid we've reached the limit of my knowledge now (in respect of Garmins), so someone with more specific know-how will need to lead you further. _________________ Richard
Meter_Man Lifetime Member
Posted: Mon Jul 27, 2009 5:03 pm Post subject: Loading your pushpins |
The best way to do this is using mapsource. You import them into mapsource from the list that you need to save as a Garmin Database file (.gdb) then select them all, click edit and make a route from selected items.
You then transfer the route to your garmin from mapsource. Now, go to Tools, My Data on the Garmin, Import Route from file and Bingo! |
Posted: Mon Jul 27, 2009 5:57 pm Post subject: Re: Loading your pushpins |
Meter_Man wrote: | The best way to do this is using mapsource. You import them into mapsource from the list that you need to save as a Garmin Database file (.gdb) then select them all, click edit and make a route from selected items.
What is Mapsource?
Have had a look at Garmin website and the download is there. However it will only install if a previous version is found on the PC taking the download. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 755 Location: Knaresborough, North Yorkshire.
Posted: Tue Jul 28, 2009 11:32 am Post subject: |
If I recall correctly, posts elsewhere in this forum have said that a copy of Mapsource is included in the Garmin Training Database package, which is here.
Dales. |
Posted: Wed Jul 29, 2009 5:11 pm Post subject: |
dales wrote: | If I recall correctly, posts elsewhere in this forum have said that a copy of Mapsource is included in the Garmin Training Database package, which is here.
Dales. |
Cant download the software at the link. It again says "Previous MapSource Not Found. Download will terminate"
Help!  |
Posted: Wed Jul 29, 2009 7:29 pm Post subject: |
Come on peeps, someone must be able to assist me to get the MS Autoroute map to my Garmin?  |
Posted: Wed Jul 29, 2009 7:53 pm Post subject: POIs to 760 |
Apologies
Have you purchased a map upgrade?
If you haven't, apparently you can't have Mapsource on your PC.
If you PM me your postal address, I'll gladly send you a CD with mapSource on it but I'm unsure if it will work until you have a ma pon your PC |
Posted: Tue Aug 18, 2009 3:20 pm Post subject: Re: POIs to 760 |
Meter_Man wrote: | Apologies
Been real busy of late and want to thank you for your offer. I ended up plotting the route on Garmin unit rather than downloading from MS Autoroute.
It has prompted a question though, how can I use the Garmin unit to its full potential if I cant get access to all the tools e.g. Mapsource?
