Pocket GPS World :: View topic - CoPilot BT GPS perm. car power
mcrobiej
PostPosted: Tue May 04, 2004 1:37 pm    Post subject: CoPilot BT GPS perm. car power Reply with quote
I have just got a CP BT GPS receiver, and I would like to mount the receiver on the rear parcel shelf in the car.
I have seen a few posts about people charging / discharging the receiver by having it plugged into the car power, but I am wondering if I could modify the unti so that it will only be powered from the car. This would mean that it would come on as soon as I start the engine (after the lock-on) and would safely power off on a night.
the other way is to use the car to charge the batteries up when the engine is on, but to let the unit go flat every night - if I choose this wayhow long before I cmpletely knacker the batteries (is it about 600 charges?)
Any ideas? there mst be someone who has a perm car fixing.
Jamie
PostPosted: Wed May 05, 2004 5:38 am    Post subject: Reply with quote
The CoPilot BT GPS has an on/off switch. So if you are not shy of a soldering iron you could modify the cabling such that the incoming power would power the receiver, and the on/off switch would connect/disconnect the battery.
That way you are also saving the battery's life since it doesn't get charged/discharged all the time. (you are right with the cycles, by the way. 600 cycles converts to roughly two years)
mcrobiej
PostPosted: Wed May 05, 2004 8:26 am    Post subject: Reply with quote
Now there is an idea - I could modify the on/off switch to be bridged by a relay - when the car power is on then the relay would energise and power the unit up, and when the car power is off, the relay would switch the unit off - EXCELLENT.
p.s. I wont forget the reverse bias diode to protect the charging circuit of the GPS module.
cool - I'm happy now !!! :D
22.063 (19 Jun 24)
