gwentvillan Lifetime Member
Posted: Tue Mar 24, 2009 8:10 pm Post subject: TMC on Navigon 8100 |
Does this work
a) with just the unit
b) will it only work with the mount
c) or will it only work with the mount and the cable plugged in ?
Is it better to specify an FM station as mine hardly ever finds TMC info otherwise
Andrew |
BigPerk Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_016.gif)
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Tue Mar 31, 2009 11:35 pm Post subject: |
Not too helpful but at least I'm
I've only used it on (c) so can't say about the other options. But I've had no real problems with reception as such so don't think FM is the point. More likely it's the often reported c**p (er - bad) coverage in the UK (depending on where you are). _________________ David
(Navigon 70 Live, Nuvi 360) |
Posted: Mon May 11, 2009 10:41 pm Post subject: |
anyone else got an answer on this ? |
Posted: Tue May 26, 2009 10:09 pm Post subject: |
the tmc aerial is part of the car charger for the 8100 |
jonandmarkuk Frequent Visitor
![](modules/Forums/images/avatars/4250564744afc069d8b4d4.gif)
Posted: Wed May 27, 2009 10:06 am Post subject: |
I normally get reasonable TMC reception, but it does depend on the FM signal. Generally found the reception to be better than the string.
I have found a TMC Y splitter on a German site which allows connection to the car's FM aerial then a USB port plugs into the holder with a thru connector for the power.
I'll track down the link and post it later tonight if anyone is interested. _________________ Navigon 8450 LIVE |
