Jeremy69 Occasional Visitor
Posted: Fri Feb 20, 2009 7:27 pm Post subject: GPS fix won't update |
My 520T has updated without problem for some time. Last week the GPSFix update stopped working and gave an error message. The message starts as below. All the other updates Map Share, Cameras etc work without problem. Anyone got any ideas off what I might do. tom Tom support haven't been unduly helpful.
ERROR: [Exception... "Component returned failure code: 0x80520015 (NS_ERROR_FILE_ACCESS_DENIED) [nsIFile.remove]" |
AndyVaughan Lifetime Member
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Fri Feb 20, 2009 8:13 pm Post subject: Re: GPS fix won't update |
Jeremy69 wrote: | My 520T has updated without problem for some time. Last week the GPSFix update stopped working and gave an error message. The message starts as below. All the other updates Map Share, Cameras etc work without problem. Anyone got any ideas off what I might do. tom Tom support haven't been unduly helpful.
Try deleting all of the ephemeris downloads in your HOME downloads folder and also deleting the contents of the ephem folder on the device.
A clear flash and pin reset might not go amiss as well.
Andy |
Posted: Sat Feb 21, 2009 11:52 am Post subject: GPSFix |
Thanks for the suggestions. I have tried them but to no effect. The saem error message remains. Has anyone a further idea? |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sat Feb 21, 2009 12:23 pm Post subject: Re: GPSFix |
Jeremy69 wrote: | Thanks for the suggestions. I have tried them but to no effect. The saem error message remains. Has anyone a further idea? |
Have you got a FULL backup of your unit. You could try saving your current set-up with a FULL backup then install the last good one and see what happens.
Don't use HOME as this will over-write the last one unless you change its name.
Always best to use Explorer and use a new name each time you backup. |
Posted: Sat Feb 21, 2009 12:24 pm Post subject: |
How often do you use the device? - if you use it every few days there is no point in downloading the data via Home, the device gets all the information it needs while its in use. I haven't bothered with the qGPS for quite some time now as I find it unnecessary and I still get very respectable times for achieving a GPS position fix.
Try using the device without it and I bet you won't notice the difference, if this is the case why try fixing something that doesn't work when its not required? - Mike |
DennisN Tired Old Man
Posted: Sat Feb 21, 2009 12:46 pm Post subject: |
Just to back up what Mike says - I haven't downloaded GPSFix since February last year. By the time I get myself ready to pull out of my drive, I've always got a fix (on all three of my devices!). _________________ Dennis
Two of them are obesiting!! |
Posted: Sun Feb 22, 2009 10:14 am Post subject: |
Same here - I don't bother with it.
Make sure you ephem folder on the device is empty though .....
Andy |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Sun Feb 22, 2009 12:07 pm Post subject: |
Hi DennisN
No, I don’t bother with the GPS Fix, no need. In fact I don’t bother with ‘Home’ either except If there is a map I may wish to download.
However, If I did try to download the GPS Fix and came up against the same snag as Jeremy69 I too would be puzzled. Not only puzzled, I would want to find the cause too. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
Posted: Sun Feb 22, 2009 4:53 pm Post subject: |
Trevor1234 wrote: | However, If I did try to download the GPS Fix and came up against the same snag as Jeremy69 I too would be puzzled. Not only puzzled, I would want to find the cause too. |
Sounds a bit like the condemned man helping Albert Pierrepoint fix a problem with the trapdoor. _________________ Dennis
alanji Lifetime Member
Posted: Sun Feb 22, 2009 7:15 pm Post subject: |
DennisN wrote: | By the time I get myself ready to pull out of my drive, I've always got a fix (on all three of my devices!). |
That'll be after you wash the car, pour a cup of tea and have a slice of toast, eh?
HOME has obviously taken notice as it no longer offers me a GPSfix update. _________________ Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner |
Posted: Sun Feb 22, 2009 7:19 pm Post subject: |
alanji wrote: | DennisN wrote: | By the time I get myself ready to pull out of my drive, I've always got a fix (on all three of my devices!). |
HOME has obviously taken notice as it no longer offers me a GPSfix update. |
I haven't got a car. (But I sometimes carry three devices on a string round my neck and run up the road howling Brrrrm, Brrrrm, Beep, Beep!!) _________________ Dennis
Posted: Sun Feb 22, 2009 7:27 pm Post subject: |
DennisN wrote: | alanji wrote: | DennisN wrote: | By the time I get myself ready to pull out of my drive, I've always got a fix (on all three of my devices!). |
I haven't got a car. (But I sometimes carry three devices on a string round my neck and run up the road howling Brrrrm, Brrrrm, Beep, Beep!!) |
Nice one, Dennis. But it does make me wonder where you plug in the charger _________________ Alan
Dell Axim & TT3
Posted: Sun Feb 22, 2009 11:50 pm Post subject: |
Thank you all. Don't bother sounds a good solution especially as there are no il effects thus far but I am curious as to why it has started to happen. |
Posted: Mon Feb 23, 2009 11:59 am Post subject: |
Hi DennisN
Stop hanging about and get on with your work. _________________ Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G |
Posted: Mon Feb 23, 2009 12:06 pm Post subject: |
Trevor1234 wrote: | Hi DennisN
Stop hanging about and get on with your work. | I haven't got any work, nobody's called me. Unless you're thinking about the pot of paint and the filler stuff sitting on the landing. I'm not good (therefore not exactly early starter) at doing It! _________________ Dennis
