Pocket GPS World :: View topic - Adding Speed Cameras to ZE-NC520 and nav n go
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Other Hardware and Software
weewillie
PostPosted: Thu Feb 19, 2009 5:25 am    Post subject: Adding Speed Cameras to ZE-NC520 and nav n go Reply with quote
Hi , I have purchased a ZE-NC520 naviceiver which is "powered by nav n go"....i wish to add speed cameras to this unit..i have copied in the speed camera txt file...the unit took about 5-6 minutes on first boot...now.the speed camera icons are visible on the maps..but i have no menu functions to enable audio warnings...after reading around , im assuming i should add diffrent skin to the memory card..as this unit isnt a PDA im not sure which version of skin i should be using to add the camera audio warning to the menu...i think this unit uses nav n go igo8. This is the unit i have http://www.zenec.com/index.php?id=123&L=1 .Thers no mention of speed cameras in the instruction manual...the only function in the warning menu is "over the speed limit"..Many Thanks in advance.WiLLy
PostPosted: Thu Feb 19, 2009 11:32 am    Post subject: Reply with quote
Hi weewillie, please can you only post one version of a topic as following replies can start to get a bit confusing! I think this would be best suited in the iGO forum as it is the software that the device runs.
please continue discussion here.
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Other Hardware and Software All times are GMT + 1 Hour
22.055 (29 May 24)
