Pocket GPS World :: View topic - Can I Change Speed Camera Text
erksome
PostPosted: Wed Sep 03, 2008 7:55 pm    Post subject: Can I Change Speed Camera Text Reply with quote
I have a igo based pna,tried to change pgps camera download text for specs from code 4 to code 1 in note pad when I try to add it to the pna, pop up states that it will not read the amended file, thought that changing specks file to gatso I would just get the camera warnings in the zone as igo dose not recognize more than 2 specs,.. anyway i can adapt the files so my pna will read them, Thanks
Sallyann
PostPosted: Thu Sep 04, 2008 5:39 pm    Post subject: Re: Can I Change Speed Camera Text Reply with quote
Well it works for me, although I don't use Notepad.
Are you sure that Notepad hasn't changed the file format in any other way, apart from changing each entry of ",4," to ",1," ?
Check the file size before and after editing. It should be exactly the same size.
erksome
PostPosted: Fri Sep 05, 2008 2:56 pm    Post subject: Thanks Sallyann Reply with quote
Hi, looked thro your posts, found your .exe. program for Ipaq 314,and transferred amended files with Notepad++. Now everything works o/k. Thanks.
Sallyann
PostPosted: Fri Sep 05, 2008 5:59 pm    Post subject: Reply with quote
Glad to help.
Sal
22.062 (12 Jun 24)
