Pocket GPS World :: View topic - It just doesn't work!
Beejam
PostPosted: Fri Apr 02, 2004 6:52 pm    Post subject: It just doesn't work! Reply with quote
Installed software...plugged in GPS mouse and it just sits there flashing (meaning it hasn't got a lock)
Casio EM500 Pocket PC
TomTom 3
Haicom 204s
Are there any simple test programs....I can't be sure that the PPC is talking to the mouse OK.
Also, will it the mouse lock on if it is not talking to the PPC?
I need ideas....I am getting really frustrated.
Thanks,
Ben.
HielandLad
PostPosted: Fri Apr 02, 2004 6:57 pm    Post subject: Reply with quote
Ben,
I don't have the same software and hardware as you, so others will be better placed to reply specifically.
However, to get the PPC to talk to the mouse (I take it that it is BT) you need to establish a partnership. It doesn't do this itself. You have to go into Bluetooth Manager, then Connect. Choose other device and establish the partnership. This should all be in your manual.
If you have done all this and it still doesn't work, then someone with the same stuff as you should have some ideas.
Alastair
Beejam
PostPosted: Fri Apr 02, 2004 7:00 pm    Post subject: Reply with quote
Thanks....but not bluetooth
HielandLad
PostPosted: Fri Apr 02, 2004 7:15 pm    Post subject: Reply with quote
Sorry - as I said unfamiliar with your hardware.
Until someone else replies, another thing to consider is that Tom Tom will need to know which com port and baud rate the GPS is using. In Copilot, there is an autoscan option or you can fill this in manually. Worth a look in options menus to see if there is something you could change.
Alastair
Beejam
PostPosted: Fri Apr 02, 2004 7:55 pm    Post subject: Reply with quote
GPS settings are com port 1 serial cable...which are correct.
Beejam
PostPosted: Fri Apr 02, 2004 7:59 pm    Post subject: Reply with quote
Do I need to install any drivers on the PPC?
22.064 (26 Jun 24)
