Pocket GPS World :: View topic - Kenwood
Kenwood
mobleyuk
PostPosted: Wed Aug 20, 2008 3:19 pm    Post subject: Kenwood Reply with quote
Please help
Can’t seem to load onto my kenwood
DNX-5220/BT
Made folder as required
Unit keeps saying disc error
Installing Pocket GPS Safety Camera Database - Non-SD Card Models
1. Create folder on your computer called 'Garmin'.
2. Launch POILoader
3. Browse for the folder where you saved and extracted the POIsin Step 1. 'extracting the Database' above.
4. Use POI loader to create the output file from database, choose 'Custom Folder' and then select the Garmin folderyou created in Step 1.
5. Burn the Garmin folder to CD-R and finalise
6. Insert CD into Kenwood unit and it will auto-update
Please advise
Kind regards
elvis123
PostPosted: Thu Aug 21, 2008 8:57 pm    Post subject: Reply with quote
Just had a 7220 fitted and had a problem loading POI's
not the same problem as you but then I have an SD slot.
The one thing I have found is that all of the instructions I read said the same as you have posted but they fail to say the path to the files on the SD should be Garmin/PIO and not just Garmin.
Once i made the POI sub folder it all worked fine.
Might be worth trying the same thing see if it helps.
22.064 (26 Jun 24)
