Pocket GPS World :: View topic - TT ONE, Wont turn on unless you remove and re-insert sd card
MaxM4XWW
PostPosted: Tue Aug 19, 2008 9:11 am    Post subject: TT ONE, Wont turn on unless you remove and re-insert sd card Reply with quote
Hi, My TT ONE has started to not turn on as if the battery is flat.
Its not flat, If you remove the SD card and re-insert it turns on.
Any ideas whats up?
dhn
PostPosted: Tue Aug 19, 2008 12:17 pm    Post subject: Reply with quote
Press the reset button with the card in the unit and again press the reset button with the card out of the unit. Reinsert the sd card and turn on the unit. See if that helps.
SpikeyMikey
PostPosted: Tue Aug 19, 2008 12:51 pm    Post subject: Reply with quote
Hi and welcome.
This may sound stupid but a friend of mine brought his TT GO up to me the other day and said it wouldn't turn on. I pressed the button for a second or two and it fired up no problem. It turned out that he had been doing a quick press with no reponse. I'm assuming this is done to prevent accidental switch on.
Just a thought Very Happy
Mike
MaxM4XWW
PostPosted: Tue Aug 19, 2008 4:33 pm    Post subject: Reply with quote
A long press does nothing, But if you take the sd card out and put it straight back in it turns on first time.
I don't really want to reset it!
Daggers
PostPosted: Tue Aug 19, 2008 4:56 pm    Post subject: Reply with quote
Resetting it is the recommended way of re-booting the device. It does not cause you to lose any data. Press the reset button!
MaxM4XWW
PostPosted: Tue Aug 19, 2008 5:00 pm    Post subject: Reply with quote
That might of fixed it Cool
22.094 (25 Sep 24)
