Quarkrad Occasional Visitor
Posted: Mon Aug 18, 2008 7:17 pm Post subject: G0 520 Postcode |
I use to have a PDA with Navigator 6 on it and this got me into TOMTOM – recently I purchased a GO 520; I am very impressed with graphics and ease of use. However, the postcode information is different on the 520 compared to the Nav 6 – I’m not sure whether it is a configuration issue or that they are different. If I navigate to SL1 4DX using the pda/Nav 6 when I enter SL1 tomtom shows SL10AA Bath Road, SL10AB Bath Road, SL10AD Bath Road etc but the Go 520 only shows SL1, SL0, SL2, SL3. When I enter the last three digits of the post code, 4DX, Nav 6 shows SL14DX Bath Road, SL14D2 Bath Road, SL14EE Bath Road, the Go 520 shows SL1, SL0, SL2, SL3 – not very useful. I was hoping the all in one Go 520 would be at least as good as the Nav 6 software but the post code information/options it provides when entering a postcode is not very useful. Basically the Nav 6 provided details of road names as the postcode is entered but the Go 520 does not. Is the way it works? Hope not as it not very useful compared to the Nav 6. |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Mon Aug 18, 2008 7:50 pm Post subject: |
Full postcodes SHOULD be available on the 520.
Can you connect your device to your PC and use Windows Explorer to examine the files/folders on it? There should be a folder called "zip" with a number of files within it.
If not, the files can be downloaded from here. Unzip the files and run the postcode installer. |
Oldboy Pocket GPS Moderator
Posted: Mon Aug 18, 2008 9:32 pm Post subject: |
The Menu Route to the Postcode is now different in the later Versions.
Do you go Navigate to ... | Address | Postcode? _________________ Richard
Posted: Tue Aug 19, 2008 9:01 am Post subject: |
Daggers - thanks. I didn't have the zip folder or file. I downloaded from your link and it all works. many, many thanks. Is this the latest version? how can you tell?
Rds. |
Posted: Tue Aug 19, 2008 9:32 am Post subject: |
One of the files you have just installed will be Great_BritainPostal.ver. Open this file using Notepad - I think the latest version should be v701. |
Gardela Lifetime Member
Posted: Tue Sep 16, 2008 10:24 pm Post subject: |
I'm just a beginner so forgive me if the answer to my question is obvious. Does the Go 520 have a 7 digit or 8 digit post code search facility? I'm confused.
Thanks in advance. |
peterc10 Frequent Visitor
Joined: Aug 21, 2005 Posts: 1761 Location: Kent, England
Posted: Tue Sep 16, 2008 11:18 pm Post subject: |
UK postcodes can be 6, 7 or 8 characters long (not sure on the 8) - for example mine is 6 (all excluding the blank space. The TT 520 will recognise, support and find them all. _________________ Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount |
Posted: Wed Sep 17, 2008 1:20 pm Post subject: |
TomTom omits the blank space in the middle of the postcode, so it will accept full postcodes of 5, 6 or 7 characters. |
carl_the_cobbler Frequent Visitor
Posted: Mon Sep 22, 2008 7:30 pm Post subject: |
I was having the same problem, recently changed map and the zip folder wasn't there. All I did was put the zip folder from my original backup into my new map folder. It seemed to work as it should, so is this going to work or can you think of any issues doing it this way?
Carl |
Posted: Mon Sep 22, 2008 7:42 pm Post subject: |
The zip folder containing the postcode files should be in the root of the device, if you have put this into the actual map folder then it won't work - Mike |
Posted: Mon Sep 22, 2008 7:47 pm Post subject: |
Oh yeah see what I have written there, cheers Mike. I did put it in the root and it seems to work fine. Was just wondering if there were any issues doing it this way, as opposed to installing it as suggested in a previous post.
I just know with Windows and stuff if you just move a installed application folder around it doesn't always work correctly as there are sometimes things going on behind the scenes that you have no idea about.
Carl |
Posted: Mon Sep 22, 2008 7:58 pm Post subject: |
carl_the_cobbler wrote: | I did put it in the root and it seems to work fine. Was just wondering if there were any issues doing it this way, as opposed to installing it as suggested in a previous post. | There are no implications from transferring the data using Windows Explorer, the folder and files are in the correct place so the device can see them and use them - Mike |
Posted: Mon Sep 22, 2008 8:17 pm Post subject: |
Top job! Thanks once again.
Carl |
