fastblatt Occasional Visitor
Posted: Mon Aug 04, 2008 4:15 pm Post subject: Auto turn on With ignition |
Hi. Does anyone know if it is possible to hardwire a tomtom one v2 to a cars ignition so that the unit switches on with the ignition and off when the car is switched off? |
lbendlin Pocket GPS Staff
Posted: Mon Aug 04, 2008 4:22 pm Post subject: |
yeah, those were the days. That's a feature that was removed by TomTom after the problems with the 910 mount. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Aug 04, 2008 5:00 pm Post subject: |
OK. But has anyone handy with a soldering iron managed to get over this since then? |
Posted: Mon Aug 04, 2008 5:32 pm Post subject: |
No, it is not possible AFAIK - Mike |
Andy_P Pocket GPS Moderator
Posted: Mon Aug 04, 2008 6:28 pm Post subject: |
Well, if you really wanted to, you could make a circuit that looked at the ignition switch and closed a relay for three seconds. The contacts of that could be wired directly across the TomTom's power switch.
Not for the faint-hearted though. |
BodgerBaz Lifetime Member
Joined: Jun 12, 2005 Posts: 368 Location: Mörsdorf, Germany
Posted: Tue Aug 05, 2008 7:09 am Post subject: |
I use the good old fashioned GO 510/710 and it will turn on with the ignition but stays on when the ignition is turned off. Not too much of a problem as I need to remove it from the windscreen when I get out anyway. |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Tue Aug 05, 2008 9:15 am Post subject: |
BodgerBaz wrote: | I use the good old fashioned GO 510/710 and it will turn on with the ignition but stays on when the ignition is turned off. Not too much of a problem as I need to remove it from the windscreen when I get out anyway. |
My trusty bulky TT710 switches on and off when connected to the ciggy lighter and engine is turned on and off. get a 10 sec countdown to cancel the switch off.
This should be a standard feature really, but like you say, I take mine out of the car as well. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15226 Location: Bradford, West Yorkshire
Posted: Tue Aug 05, 2008 9:43 am Post subject: |
as lutz said though, they released a rubbish mount for the 910 whereby the connections would come apart far to easily so you would constantly get the 10 second count-down.
great that, instead of dealing with the problem (rubbish mount) they just hid the effects of it...
MaFt |
Oldboy Pocket GPS Moderator
Posted: Tue Aug 05, 2008 11:27 am Post subject: |
MaFt wrote: | great that, instead of dealing with the problem (rubbish mount) they just hid the effects of it... | I'm sorry, but I've never had a problem with the 910 mount.
Well, I'm not sorry really, I'm rather glad that mine is OK.
BodgerBaz wrote: | but stays on when the ignition is turned off |
There is an option that you need to tick on the 2nd page of Battery saving preferences _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Wed Aug 06, 2008 7:02 am Post subject: |
Oldboy wrote: | BodgerBaz wrote: | but stays on when the ignition is turned off |
There is an option that you need to tick on the 2nd page of Battery saving preferences |
KEWL. Thanks Richard I've found it |
tenorplayer Regular Visitor
Posted: Wed Aug 06, 2008 3:27 pm Post subject: |
my 910 mount used to switch on and off when hitting bumps etc ( a common fault I believe) but TT sent me an improved model mount and brill so far for nigh on 2 years (give or take ) |
Posted: Wed Aug 06, 2008 7:07 pm Post subject: |
I saw the bit about the battery preferences and thought that would help with what I want to do but I don't think my ONE V2 has it. Well.... I can't find it. |
Posted: Thu Aug 07, 2008 7:26 am Post subject: |
fastblatt wrote: | I saw the bit about the battery preferences and thought that would help with what I want to do but I don't think my ONE V2 has it. Well.... I can't find it. |
It sounds as though yours is running with the 'fewer options' facility. The battery option is on page 6 of 7.
If you don't have 7 pages then try clicking on Change Preferences | Show more Options (on page 3 of 3). |
mikewall Regular Visitor
Posted: Thu Aug 07, 2008 9:25 am Post subject: |
Andy_P wrote: | Well, if you really wanted to, you could make a circuit that looked at the ignition switch and closed a relay for three seconds. The contacts of that could be wired directly across the TomTom's power switch.
Or anyone with normal sized fingers, perfect eye sight, your talking keyhole surgery on the TT, and forget the warrenty if/when it goes wrong! Best option would be to get a 910! |
Posted: Thu Aug 07, 2008 9:31 am Post subject: |
A modification like this could be done, but unless you are used to working with surface mount electronics and use of very fine tip soldering irons then leave this idea well alone.
Another thing to consider is the duration the button needs to be pressed, a couple of seconds is the norm, 7,481 needed a five second press and on some newer units the on/ off button doubles as the reset button (when you press it for 15 seconds) - so make sure whatever you wire in for the auto on/ off can accommodate the above - Mike |
