Pocket GPS World :: View topic - Connect to computer
Connect to computer
rickenbacker
PostPosted: Sat May 31, 2008 12:09 pm    Post subject: Connect to computer Reply with quote
For some reason my TT 710 keeps asking if I want to connect to computer, any ideas anyone?
Oldboy
PostPosted: Sat May 31, 2008 3:30 pm    Post subject: Reply with quote
It's the way that the software works.
You obviously have the Device connected by the USB lead when the PC and the Device is on.
TT Via 135 App 12.075: Europe Map v1135
john877
PostPosted: Sat May 31, 2008 7:51 pm    Post subject: Re: Connect to computer Reply with quote
Make sure you use the correct disconnect device procedure if you decide to connect or you could corrupt your tomtom software .
The general consensus on the site is to make a back up copy in windows explorer
Hope you do not think I am telling you how to suck eggs
PostPosted: Tue Jun 03, 2008 11:46 am    Post subject: Re: Connect to computer Reply with quote
When? Cool
If it happens with NOTHING connected - it's a fault.
Try a reset or a return to factory settings and if it still does it, send it back.
If it happens when you are connected to a computer - that's normal.
But I guess you realise that!
If it happens when you connect to the power supply - are you using the genuine TomTom one?
I've seen this happen with Garmin models that use the USB connector for power as well when using a TomTom car charger instead of the Garmin one (but I've never seen it on a TomTom when using the same TomTom charger).
rickenbacker
PostPosted: Sat Jun 14, 2008 11:19 pm    Post subject: Reply with quote
Yeah, sorry for not explaining the problem correctly. It happens while I use it
in the car. When I tap "No", the voice prompt goes off. Tried resetting it etc but no joy. Thanks for the replies.
PostPosted: Sun Jun 15, 2008 1:18 am    Post subject: Reply with quote
So are you using the genuine TT car charger?
And what "voice prompt goes off"?
dsouter
PostPosted: Mon Jul 14, 2008 8:12 pm    Post subject: Re: Connect to computer Reply with quote
I had this with a 720. I returned it for a replacement. It is caused by a faulty pcb apparrently.
Duncan
never mind eh!!!
go 1005
22.094 (25 Sep 24)
