75Connoisseur Occasional Visitor
Posted: Sun Jun 01, 2008 12:21 pm Post subject: Where has my speed camera POI file gone? |
Hi all. I have a Garmin 310T but haven't used it for a couple of months. I am sure I used to be able to select the safety camera POI file and get all the cameras in a list, starting with the closest. It appears to have gone. Am I doing something wrong? I have updated the latest camera database, but it didn't help. Please help! |
Posted: Sun Jun 01, 2008 12:23 pm Post subject: |
Usually under something like
My Locations, Custom POIs
Page 49 of the Owner's manual 1.77 Mb PDF
Posted: Sun Jun 01, 2008 12:25 pm Post subject: |
Hi PaulB. Thanks for the quick reply. However, it isn't there. If i simulate the route, the cameras show, but I can't find the 'list'. |
Posted: Sun Jun 01, 2008 12:27 pm Post subject: |
Are you sure these aren't the Garmin (Cyclops) Camera you are seeing?
How did you load the PGPSW Database to the Nuvi? |
Posted: Sun Jun 01, 2008 12:30 pm Post subject: |
I use the POIloader. I DEFINITELY used to have a list of cameras/zones etc. starting with the closest to my current location, the list has gone, it is not in Custom POI's. |
Posted: Sun Jun 01, 2008 12:34 pm Post subject: |
Which database are you using (Single File, Consolidated, Speed Zoned)?
What do you see in Custom POIs?
Do you have the Garmin Cyclops Database installed? |
Posted: Sun Jun 01, 2008 12:37 pm Post subject: |
I used single file. I see all my other POI's i.e. ATM's, shopping etc. I haven't downloaded the cyclops to my knowledge, but then I don't know, I just expected EVERYTHING to be in the single file. |
Posted: Sun Jun 01, 2008 12:41 pm Post subject: |
How many other POIs do you have installed?
With the Single File Database you should see an entry "pocketgps_uk_cameras" is that definately not there?
What if you load the PGPSW Database on it's own? i.e. with no other POI files. |
Posted: Sun Jun 01, 2008 12:44 pm Post subject: |
75Connoisseur wrote: | I use the POIloader. I DEFINITELY used to have a list of cameras/zones etc. starting with the closest to my current location, the list has gone, it is not in Custom POI's. | I have sent you an e-mail containing a step by step guide showing how to get the list displayed on the device, try following that and see if it works - although it is no different to the advice offered so far (its an old document I threw together quite a while back).
One thought though when you last loaded the POI were they on an SD card, if so is that still in the slot on the device? - Mike |
I will try deleting the POI database and installing the safety camera database on it's own. I'll be back! Thanks for your help so far. |
Posted: Sun Jun 01, 2008 2:20 pm Post subject: |
Paul and Mike. Thanks very much for your help, now sorted. The problem came down to the fact that i was getting muddled between loading on the SD card and/or on the Nuvi. Things were loading on one and not showing on the other or wiping out what was already on one or the other. Confused? Yes, so was I! Thanks again. Paul. |
