Pocket GPS World :: View topic - Speed camera tolerances
hailstorm
PostPosted: Wed May 07, 2008 8:49 am    Post subject: Speed camera tolerances Reply with quote
I don't know if I'm worrying about nothing but this morning I was passing a gatso and was just edging over 30 on the speedo. Prob 30-33mph. I did stamp on the breaks just as I went into the white line area. I presume speed cameras have a certain tolerance?
Only started driving 4 days ago so would be a nightmare if I got flashed. Not that I go speeding around the place.
GPS_fan
PostPosted: Wed May 07, 2008 8:56 am    Post subject: Reply with quote
The commonly quoted figure is 10% + 2mph
30mph + 10% (3mph) + 2mph = 35mph
60mph + 10% (6mph) + 2mph = 68mph
HOWEVER, some police forces and safety camera partnerships are rumoured to employ a zero tolerance - meaning that if you're over, you get done.
Having said that, though, your speedo should show your speed to be about 10% over the speed that you're actually travelling - so if it showed 33mph, you were probably only doing about 30mph
Does this help?
Andy
PostPosted: Wed May 07, 2008 8:57 am    Post subject: Reply with quote
They do but the trigger speed is set by individual partnerships. I'd expect a 30mph camera to fire at 34-36mph or greater.
Edit: Beaten to it! I see you're using our database, did it not alert you?
hailstorm
PostPosted: Wed May 07, 2008 9:11 am    Post subject: Reply with quote
Ok thanks. I think I'll just try and be extra extra alert. I already know full well there are two speed cameras along the road I travel to work. Just so many things to try and concentrate on. That or just avoid the road altogether.
