Pocket GPS World :: View topic - cannot see POI's that are quite a distance away!
mmace
PostPosted: Fri Mar 19, 2004 8:58 am    Post subject: cannot see POI's that are quite a distance away! Reply with quote
hi guys, I'm new to all this. Some of the POI's I am using in tomtom include my own family & friends as well as the stadium one that comes with it.
The problem is, when I go into them in TTN all I can see is the near ones, I can't see anything more that 50 miles away in the list. What can I do?
Maff
Privateer
PostPosted: Fri Mar 19, 2004 10:35 am    Post subject: Reply with quote
Hi Maff,
TTNav will only display a certain number of POIs on the screen, regardless of whatever your zoom level is set to. The default maximum is 20 POIs. This can be changed by going into “Properties”, this can be done either from the Map screen which is File | Properties menu, or from the Navigator Menu, keep tapping the “More” button until you find the “Properties” icon.
Once you’ve found “Properties” tap the “Advanced” button and scroll down to nearly the bottom of the page and you will see a heading fro “POI Settings”. There’s a box for “Maximum POI on Map”. Thumbs Up
Alternately, if you’re showing a lot of different POI types, try removing the ones that are currently less important to you. Smile
Robert.
Garmin Camper 770 LMT-D
22.063 (19 Jun 24)
