Pocket GPS World :: View topic - TTGO 720 POIs
TTGO 720 POIs
scooby-bloo
PostPosted: Mon Apr 21, 2008 2:09 pm    Post subject: TTGO 720 POIs Reply with quote
Hi.. I've just come across your site, I've downloaded to my pc a few POI's what do I do next? I can see them in a folder on my pc but haven't a clue what to do next to get them to my TT GO 720.
PostPosted: Mon Apr 21, 2008 3:11 pm    Post subject: Reply with quote
Easy.
Connect your Go to the PC with a USB lead (or the dock that came with it - either will do).
Windows will recognise the Go as a new hard drive (two new hard drives if you have an SD card installed as well).
Assuming you haven't added a map on an SD card, using Windows Explorer (or 'My Computer'), browse to the TomTom internal memory and find your named map folder (it will be called "Western_Europe" or similar on a 720)
Now the POI files you downloaded will have arrived as a "zip" archive. You need to right-click on it and select "extract all" from the menu to extract all the individual files.
Each POI set consists of a data file (e.g "shops.ov2") and a picture icon file ("shops.bmp"). Simply copy both of them into the map folder you located above. Repeat for each POI category you want.
Just be aware there is a limit of around 200 categories you can add. (and this includes the TT-supplied camera database - you'll see those when you start looking at the map folder's contents.
To see them on the TomTom display, you need to go to "Show POIs on map" in the menus.
22.094 (25 Sep 24)
