Pocket GPS World :: View topic - Mapshare updates error?
crazyhazy
PostPosted: Tue Apr 01, 2008 4:43 pm    Post subject: Mapshare updates error? Reply with quote
After the updates have 'appeared' to install via Tomtom Home, and clicking done to take you back to the menu screen, the number of updates doesnt appear to change - only about once a week! I have been stuck on 15889 map share corrections in use for days now, but the update option is there nearly every time I connect Confused
Graham
Tomtom One
App 8.010 (9369/080529) OS:190943
GPS v1.21, Boot 5.5011
United Kingdom and Replublic of Ireland v885.4058
PostPosted: Tue Apr 01, 2008 8:43 pm    Post subject: Reply with quote
Just another bit of Home that doesn't work correctly....
EITHER the Mapshare "status indicator" add-on doesn't tell the truth OR the Mapshare downloads are empty, or knowing TomTom's software it's probably both....
Without any other way of reading/logging the changes made by mapshare, we've no way of telling.
All you can do is compare your figures with someone else who has the same map version.
crazyhazy
PostPosted: Wed Apr 02, 2008 3:18 am    Post subject: Reply with quote
Another question cleared up - thanks.
Graham
Tomtom One
1952kev
PostPosted: Wed Apr 02, 2008 11:00 am    Post subject: Reply with quote
I have identical versions to you.
Just went on to Home and was told I had 3 weeks (2000+) of map updates.
Downloaded (after 3 failed attempts/timeouts) and now shows 15889!
Unfortunately, I didn't take note of the figure before I downloaded.
spikestorey
PostPosted: Wed Apr 02, 2008 4:33 pm    Post subject: Reply with quote
Should be all fixed now I have been talking with tomtom
last note from them
I did not have to do this it just started updating it takes several updates to get it to where it should be
Good Luck
If you are still offered mapshare updates after unticking all preferences please leave the mapshare community and then log out of Home. Then log back in to Home again and join the mapshare community again via the emulator in 'Operate my Go'. Please also set your preferences via the emulator.
I hope this resolves the issue for you. Do not hesitate to contact us if we can help or assist further.
22.071 (03 Jul 24)
