Pocket GPS World :: View topic - garmin i3 borked :(
garmin i3 borked :(
paulyoung666
PostPosted: Sat Mar 29, 2008 8:28 pm    Post subject: garmin i3 borked :( Reply with quote
it has stopped locking onto sattellites Sad , tried it normally and diagnostically , no matter which way i point it , it wont see anything at all , is there any magic i can perform or not ??? , and if it cant be sorted what do i replace it with , i would stick with garmin i reckon but wouldnt want to pay too much , tia -- paul Smile
PaulB2005
PostPosted: Sat Mar 29, 2008 10:11 pm    Post subject: Reply with quote
First of all how are you powering it? Car adaptor or batteries? If batteries what type?
How long are you leaving it to get a lock? I used to find during poor weather it can take a bit longer.
Make sure you have a backup of your POIs and backup your favourites with EasyGPS
Then try a reset. Switch the unit off, hold down the Back Button (Left), the Wheel (centre) and then switch on with the Power Button (right). Tricky but possible. Then it'll ask you something about resetting user data, say Yes. This will reset it back to Factory Settings.
Then put fresh batteries in, find a clear spot and give it upto 20 minutes to get a lock.
If it works reload the POIs and favourites and reset your settings.
If you want to consider a new unit the 200 (or 200W) is a good replacement for the i3.
paulyoung666
PostPosted: Sat Mar 29, 2008 10:53 pm    Post subject: Reply with quote
hiya , tried all that and nothing , forgot to mention , i was thinking about getting a bluetooth enabled unit , any thoughts on that Smile
Adamj
PostPosted: Sat Mar 29, 2008 11:41 pm    Post subject: Reply with quote
If the firmware version is 3.xx then flash to 2.70 and see if that saves the day.
Someone on here the other week had a very similar problem with his i3 and nearly threw it in the bin but downgraded firmware and the i3 works perfectly.
paulyoung666
PostPosted: Sat Mar 29, 2008 11:48 pm    Post subject: Reply with quote
cheers , worth a go if nothing else Smile
22.105 (30 Oct 24)
