Pocket GPS World :: View topic - Copying TT files onto a larger SD Card
BigTim53
PostPosted: Tue Mar 11, 2008 1:21 pm    Post subject: Copying TT files onto a larger SD Card Reply with quote
I have TT710 (version 7.162). The SD card which came with the TT is nearly full up. Is it possible to copy the contents of the card onto a larger SD card so that I have greater room for additional files.
If the answer is yes what is the best way of doing this.
Tim
PostPosted: Tue Mar 11, 2008 1:45 pm    Post subject: Reply with quote
Should be no problem. Copying to a new SD card is a very similar process to doing a backup - just copy and pasting using Windows Explorer.
See the FAQs forum topic for instructions.
You can either use the TT as your card reader and swap cards, using the PC as a temporary store; or if you have a dedicated card reader you can copy from one to the other.
You MAY need to re-authorise the map using the product and device codes, so make sure you have those handy.
22.055 (29 May 24)
