Hearing Occasional Visitor
Posted: Sun Mar 02, 2008 9:32 pm Post subject: Navman S50 installing this speed Camera Data Base |
I have a Navman S50 with Camera database pre loaded. If I install this speed camera data base, do I simply turn of the Navman installed product? or will the existing data be over written if I use the same names.
Bernie Hall |
mostdom Pocket GPS Moderator
![](modules/Forums/images/avatars/20941253924f0d8a4db1041.jpg)
Joined: Jul 10, 2006 Posts: 1964 Location: Surrey, UK.
Posted: Mon Mar 03, 2008 11:36 pm Post subject: |
Hi Hearing, Welcome to the forum.
When you move over to the PGPSW product you can then disable the Navman database. I recall it being impossable to remove the pre installed database, but dissabling it will not affect anything.
Hence the PGPSW databse will not overwrite the navman database!
[PITCH ON]
I sure you will discover for yourself shortly, that the PGPSW safty camera database is regarded as one of the most accurate and uptodate databases on the net. Enjoy!
[PITCH OFF] ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Dom
Navigon 7310/iPhone Navigon&Copilot |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Mar 04, 2008 10:02 am Post subject: Re: Navman S50 installing this speed Camera Data Base |
Hearing wrote: | I have a Navman S50 with Camera database pre loaded. If I install this speed camera data base, do I simply turn of the Navman installed product? or will the existing data be over written if I use the same names.
Bernie Hall |
Further to Mostdom's post, you don't have to turn off the Navman safety cams - they will work quite happily with the PGPSW data. There might just be the odd camera that Navman has installed which is not on the PGPSW database - most unlikely, though as PGPSW data is acknowledged to be the best and most comprehensive
However, having both active will mean double warnings...your choice.
Graham _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
