Pocket GPS World :: View topic - tomtom ONE - turns on, goes to splash screen, then freezes
pauldoherty
PostPosted: Fri Feb 29, 2008 4:16 pm    Post subject: tomtom ONE - turns on, goes to splash screen, then freezes Reply with quote
Please help. I first took my ttone out of the box and it was working fine, and today I decided to install the home2 software and update. I installed the software from the tt and then connected it. I first did a backup and it wouldn't finish. then I updated the software and it couldn't open a particular file.
After this when I powered it on, it can on, the splash screen came on and then it went off again. I have tried several times to update the software and it keeps hanging on different files - the latest message saying it couldn't access G:system. Now when i power up the tt it goes to the nighttime splashscreen and then stops - you have to push the reset to clear it.
Can you please offer some suggestions as I am at my wit's end! I have tried numerous resets
dhn
PostPosted: Fri Feb 29, 2008 4:40 pm    Post subject: Re: tomtom ONE - turns on, goes to splash screen, then freez Reply with quote
I'm not clear when you say the backup 'wouldn't finish'. What did it do, or not do?
Anyway, I would connect the unit to the computer, make a full backup using Explorer, not TTHome, start up TTHome, choose to remove items from the unit and select the application. TTHome will give a warning but do it anyway (again, AFTER the full Explorer backup).
Then, go to Update my unit and you should get the newest firmware. Install it and see if the issue is resolved. If not, perhaps download and run the 'clear flash' tool from TomTom's site and try running it.
PostPosted: Sat Mar 01, 2008 7:19 pm    Post subject: Reply with quote
Correct me if I'm wrong....
You realised how important it was to do a backup before changing anything.
You tried to do the backup and it failed?
So you then went ahead and changed things anyway?
Confused
22.064 (26 Jun 24)
