Pocket GPS World :: View topic - How to open a nuvi
How to open a nuvi
parbrook
PostPosted: Mon Feb 11, 2008 7:26 pm    Post subject: How to open a nuvi Reply with quote
I have a 310D and the power switch is playing-up.
I have to press it really hard to switch it on and off.
I'd like to open it to see if I can fix the switch, but before I make a mess of the case, i'd appreciate any pointers from anyone who has already done this.
I'm assuming that I need to insert and twist something flat into the join, but I would to attack it in the right place (if there is one).
PhilHornby
PostPosted: Tue Feb 12, 2008 12:15 am    Post subject: Re: How to open a nuvi Reply with quote
parbrook wrote:
I'd like to open it to see if I can fix the switch...
I'm assuming that I need to insert and twist something flat into the join..
I *think* there might be a screw behind the serial no. barcode.
(I took the aerial apart and removed the magnet - while it was off, I had a go at levering the case apart and it didn't want to know ... hence the theory about the screw. Mine's still under warranty, so I didn't try levering too hard Confused )
I got a set of tiny torx screwdrivers and a polythene? 'levering tool' off ebay - meant for dismantling mobile phones apparently.
crazyfingers
PostPosted: Tue Feb 12, 2008 2:22 am    Post subject: Re: How to open a nuvi Reply with quote
You really sure you want to do that? Garmin is good about replacing units that have problems. But if you open it and can't fix it Garmin's not likely to want to take it back then.
Garmin Nuvi 750 w/City Nav 10 N. America & 08 Europe
Garmin iQue 3600/City Nav 08, City Select v6/v5
Garmin eTrex Vista Cx, Topo USA, Topo Canada
eTrex Legend (Original)
A Magellan that got wet and died on a canoe trip in 02
parbrook
PostPosted: Tue Feb 12, 2008 9:19 pm    Post subject: opening a nuvi 310 Reply with quote
Thanks for the replies.
Mine's way out of warranty, so I assumed that Garmin would not be interested.
However, I'll give them a try.
I checked beneath the serial number barcode label and there is no screw.
crazyfingers
PostPosted: Wed Feb 13, 2008 4:18 am    Post subject: Re: opening a nuvi 310 Reply with quote
My First eTrex Legend was about 2.5 years old when the screen went bonkers. They took it back and replaced it.
I think that it's worth a try before trying to open it.
swing
PostPosted: Wed Feb 13, 2008 6:05 pm    Post subject: Reply with quote
Indeed - Garmin may take a while to answer the phone, and they may not repair it for free (although there are many tales of them repairing out of warranty devices for free), but their repair charge is a lot less (even now) than a new unit, and they may well supply you a different unit, or at least one with newer maps, so the cost may actually be well worthwhile...
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
22.062 (12 Jun 24)
