Pocket GPS World :: View topic - Streetpilot C510T not web updating
johnj60
PostPosted: Sun Feb 10, 2008 4:36 pm    Post subject: Streetpilot C510T not web updating Reply with quote
New to all this but here goes. When I run webupdater on a new C510T it finds the device ok and says I need software Version 6.00. Downloads but then says there is not enough space on disk.
I have a 2GB SD card in and unit reports Software version 5.90 installed which from reading other posts looks like a Garmin ghost version.
PaulB2005
PostPosted: Sun Feb 10, 2008 5:30 pm    Post subject: Reply with quote
I'm seeing someone this week who has the same problem with a 660FM.
Can you confirm you are downloading the firmware to the PC and running it from there and not on the unit itself?
johnj60
PostPosted: Sun Feb 10, 2008 8:13 pm    Post subject: Reply with quote
Paul, I have checked and have the following if its any help to you:
StreetPilotc5xx_regionfileonly__60[1].gcd 7327KB GCD file in temporary internet files
The only updated files on the Garmin are:
GarminDevice 14KB XML document
GUPDATE.GCD 0KB GCD file
006B048201 32KB bin file (from the first try)
johnj60
PostPosted: Sun Feb 10, 2008 8:35 pm    Post subject: Reply with quote
Update.
I tried the update via the downloadable file and it tries to install to the Garmin which can't take the 7Meg file, changed it so it pointed at the SD card and all worked ok.
The problem I can see with webupdate is it will only point to the Garmin and not the SD card.
PaulB2005
PostPosted: Sun Feb 10, 2008 9:14 pm    Post subject: Reply with quote
Thank you. I suspected this was the case and have already downloaded the firmware seperate from WebUpdater.
I've just done a dry run and it states "Please select the letter that represent your card reader" (or simalar..)
22.064 (26 Jun 24)
