gilbates Regular Visitor
Posted: Thu Mar 11, 2004 8:51 am Post subject: POI Limits |
is there a limit to the amount of poi information the pc side of CPL4 can handle because i have a small prob
i have changed alot of ov2 files to XLS and imported them perfectly to the POI manager
they can all be seen within the manager and are all sorted by a catagory prefix , ie ..national trust , airfields , so on and so on , when the zoom button is clicked in the manager window the map goes to where the item should be correctly but displays nothing in the way of a push pin or relevant txt
some of my prefix entries are fairly long would that affect this , for example GATSO has been changed to CAUTION POSSIBLE SPEED CAMERA APPROACHING , does the length of the txt field under the name tab have a character limit , therefore not display info on the map
i have downloaded my custom POI dbase to my IPAQ but when searching custom places it finds nothing
it seems the imported poi information on the pc is being read by the poi manager but not transfered , displayed or recognised by the CPL4 map software
is the file that is created by addinig poi information in a format that can been saved seperately from the rest of the CPL4 programe , if a re-install of the desktop software is needed it would save a lot of time , re-importing one or two poi files is ok but when you put 10 or 11 of them in it takes ages
and the poi manager really slows to a crawl the more you add , even on a fast machine |
Posted: Thu Mar 11, 2004 9:01 am Post subject: |
i have just noticed by chance that some cameras are displayed but are not in poi manager
GATSO 193 is displayed on my map on the pc but its not in the manager dbase
wierd
how can i resolve this |
Posted: Thu Mar 11, 2004 9:07 am Post subject: |
digging a bit deeper GATSO cameras above 1517 do not display only those below this number
hope some of this helps to resolve some issues to those in the know |
Posted: Thu Mar 11, 2004 7:38 pm Post subject: |
well i have tried a few different things now to resolve the issue and i may have sorted it
i deleted all the poi`s i had previously added to CPL4 and created one large XLS file with Excel containing all the previously entered data
i then added that as a single file , still the problem of no push pin positions remained
so i deleted that file and imported the files in catagories
little chef
nat trust
steam trains
and so on
it was after i had added airports that things changed, suddenly all push pins disapeared ?
so i removed airports from the poi manager and the push pins and other places seem to have returned
i havent done too much testing yet but the push pins i was using for checking poi positions are still there on the map and havent disapeared yet , that only happens after airports are added
so airport data seems to have been the thorn in this instance
again i havent looked at the airport XLS file in detail , at a glance it seems the same as the other poi`s and imported without a glitch , maybe the fact that the airport call signs are used in the description has something to do with it , who knows ? |
Posted: Thu Mar 11, 2004 7:45 pm Post subject: |
oh and one more thing
i have just cottoned on to the fact that you can make CPL$ say anything you like
oh what fun i`m having now 8O |
ap Occasional Visitor
Joined: Sep 20, 2003 Posts: 10 Location: Warrington UK
Posted: Sat Mar 13, 2004 12:06 pm Post subject: |
That sounds fun. How do you do that? |
Posted: Fri Mar 19, 2004 11:50 pm Post subject: |
sorry bout l8 reply m8
had some family matters to deal with lately
lets start from the top CPL4 is a brill programe and realy dosent want messin with , it does what it says on the box well
however if ya have a sense of humor or like me you like CPL4 to say " your home master " or "please make sure you have your seat belt on" amongst other things , the answer is simple
create a XLS file with co-ordinates located from the pc map part of CPL4 and then put whatever txt you want said after it , your pda will always repeat whatever txt is writen, import it into your custom dbase and then copy to the pda
dont forget though that if you use coma`s or full stops or any other symbol , copilot says outloud those annotations , at the momment my speed camera dbase needs changing because after it says " caution possible speed camera ahead" there is a colon and then the camera number , of course CPL4 says the word colon , so that needs changing when i get the time
another thing for instance , at the end of your road just type after the co-ordinates of that location , " please check your seat belt is on " stupid maybe but how many of us realy do forget
this works two ways however , going and coming or even within the vacinity of the co-ordinates , its good when your off on a journey but daft when your nearly home and you have just driven 200 miles with your seat belt on
its all basic stuff but with imagination you can have a little fun , and theres nout wrong with that  |
