alvaro Occasional Visitor
Posted: Fri Dec 07, 2007 11:05 pm Post subject: nuvi 250 calibration |
hi i have a nuvi 250 and i find it slightly innacurate, when i approach a turning it tells me to turn just after the turning is there a way of clibrating the screen thanks |
PlaneApart Occasional Visitor
Posted: Sat Dec 08, 2007 1:37 pm Post subject: |
I would suggest a "Master Reset" to cure the problem.
Press the top right corner of the screen whilst switching the Nuvi on.
Keep pressing until you get the reset option and press yes.
You'll have to reselect some of your options after, but well worth the effort. |
Posted: Sat Dec 08, 2007 7:13 pm Post subject: |
thanks will try that and report back |
Posted: Sat Dec 08, 2007 7:25 pm Post subject: |
have tried to do master reset like you said holding top right corner but does not seem to do anything , i noticed there is a reset button on bottom of unit will that help . |
Posted: Sun Dec 09, 2007 10:51 am Post subject: |
I've got a 310D and the master reset works with that, and I think yours is basically the same.
I suggest you try again, making sure you're pressing the top right corner of the screen as you switch the Nuvi on, and don't stop pressing until you get the reset options. You'll get all the loading screens first, but just keep pressing unti the reset appears. |
inspiredron Frequent Visitor
Joined: Dec 17, 2006 Posts: 302 Location: Ellesmere UK
Posted: Sun Dec 09, 2007 5:46 pm Post subject: |
Different models use different corners for hard reset. If top right does not work try the other corners. You may even get into maintenance mode as on the 660. Keep pressing the corner until you get the appropriate message but don't try to push th escreen out of the back of the nuvi! ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
graygo Occasional Visitor
Posted: Mon Dec 10, 2007 11:29 pm Post subject: |
Try sliding the power button to the left and hold it there for about 30 seconds, this should allow you to enter calbration mode. |
MaFt Pocket GPS Staff
![](http://maft.co.uk/avatars/pgpsw.jpg)
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Tue Dec 11, 2007 5:31 pm Post subject: |
graygo wrote: | Hi,
tat will calibrate the touch screen though, the OP was meaning the map-lag!
MaFt |
PeterSm Lifetime Member
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Joined: May 18, 2006 Posts: 49 Location: Leighton Buzzard, UK
Posted: Thu Dec 27, 2007 10:45 pm Post subject: |
PlaneApart wrote: | I would suggest a "Master Reset" to cure the problem.
250(w) uses bottom right, held down when powering on to do a "user" reset. Seems to work ok |
