Pocket GPS World :: View topic - BT gps receiver and BT headset ??
jackeen
PostPosted: Sat Feb 28, 2004 1:55 am    Post subject: BT gps receiver and BT headset ?? Reply with quote
Hi all,
Before I go and but Tomtom with Fortuna clip BT receiver is there going to be any problem with using my BT headset at the same time.
Will I be able to pickup calls on the headset while using TOmtom with the BT receiver ??
Many thanks
8O 8O 8O
jackeen
PostPosted: Sat Feb 28, 2004 2:01 am    Post subject: Reply with quote
Sorry forgot I've the XDA2
tom9851
PostPosted: Sat Feb 28, 2004 7:48 am    Post subject: Reply with quote
I may be wrong here but I don't believe you can have both at the same time. I do believe you can only have one bluetooth device connected at any one time. If your XDA is busy running TomTom and connected to your GPS via bluetooth, I don't see how you could answer an incoming phone call on your XDA with your B/tooth headset, unless as soon as you were starting to receive an incoming phone call you terminated TomTom and closed the bluetooth link to the GPS and established a bluetooth link to your headset! I was considering buying an XDA myself but opted instead for an Ipaq and a seperate bluetooth nokia phone for this very reason - but knowing my luck I am totally wrong about this!!!
Sorry I can't be more definite - but am sure someone else here is far more knowlegable about this.
Tom
PostPosted: Sat Feb 28, 2004 9:28 am    Post subject: Reply with quote
You can use your BT headset for the telephony side and your BT GPS on the Nav side at the same time as they use different BT services (Headset and Serial Port Profiles).
22.064 (26 Jun 24)
